ram 2004 tires
Old Feb 23, 2011 | 03:38 AM
ram_as_hard_as_you_can's Avatar
Default ram 2004 tires
hey i am new to this forum
i have 2004 reg cab 1500 5.7 hemi 4x4
what is the widest tire i could fit because i drive on sand
in sand wider is better
and what are the tires in this video
http://www.youtube.com/watch?v=IhnAwUjMUl0
Old Feb 23, 2011 | 07:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site.
12.5's are about as wide as you can go without getting into specifics on rim backspacing or rim spacers
Old Feb 23, 2011 | 08:34 AM
12.5 inch or what ?
Old Feb 23, 2011 | 08:40 AM
Old Feb 23, 2011 | 09:27 AM
cjs4444's Avatar
cjs4444
lol dude there is no way to tell
Old Apr 21, 2011 | 07:06 PM
Plainbroke's Avatar
Plainbroke
Just drop the air preasure in your tires to 15-20psi and you can go fine in sand, Dick Cepeks go pretty good aired down too. Momentum makes a huge differance too. once you get it moving keep enough throttle to keep it going. Or buy some paddles for the rear..
Old Apr 21, 2011 | 07:47 PM
HammerZ71's Avatar
HammerZ71
True 'dat! I bought the FCIIs because I run 360 miles of mostly interstate between Florida and my small piece of farmland in south/central Ga. Then I play hard (hunt/fish, etc.) when I'm there. I needed a tire that would not get chewed to sh*t on the pavement but still be able to go in the low country hog huntin'.
The FCIIs were a perfect fit for me, a true A/T - M/T hybrid. The center tread is more like an A/T, but the side blocks are quite aggressive and it has some pretty nice side-biters. When you air down, you put more of the outer blocks down and the foot-print gets flatter. Can usually hang with the boys with the real aggressive M/Ts then with no problem...
Old Apr 22, 2011 | 02:01 AM
Owensue's Avatar
Owensue
Taken from... http://news.pickuptrucks.com/2010/04...n-in-moab.html
"40x14.50 tires on 17-inch wheels. The BFG K2 Mud Terrains with Kevlar sidewalls offer good traction, with excellent sidewall protection at low inflation pressures"
Google works wonders...
