Is spray in bed liner worth it if I am putting a tonneau cover on? (picture)
Old May 19, 2011 | 03:47 AM
T_Visk's Avatar
T_Visk
Default Is spray in bed liner worth it if I am putting a tonneau cover on? (picture)
I just bought an 06 ram with a pretty beat up bed and wondering if I should do anything to the bed if I am going to put a cover on top of it anyways. Opinions? Also, I don't do a lot of gravel driving and keep my ride pretty clean but do you think it would be worth it to do the rockers/bottom inch or two of the outside to prevent future rust or just wait til I have a problem? I want to put my money in the most logical places first before I invest in fun stuff. If anyone has any advice or opinions that would be greatly appreciated.
Old May 19, 2011 | 07:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would spray it to try to help prevent future issues if you are planning on keeping the truck for many years to come
Old May 19, 2011 | 07:49 AM
Fav40's Avatar
Fav40
I used the bed on my 00' Silverado 2500 quite often and only had a warped OTR drop in.
My 07' Ram is a pretty much a daily driver. I got a Line-X OTR spray in and later put a Truxedo Lo-pro tonneau cover over it. Bully tail gate lock(rarely use) and a bed divider have all worked well for what I use it for. Did I need to spend the extra $$$ for the premium spray liner ? Naaa but it's neat looking.
Old May 19, 2011 | 05:37 PM
T_Visk's Avatar
T_Visk
Would I have any problems if I had a cover though because it would hardly ever get wet?? I don't know, it seems like an expensive project to do it right. I found some spray can stuff they use at a buddys shop to do like shelves and stuff, he thinks it would work great in the bed but I'm not sure. The bed won't be used all the time, once a month or so or something like that. IDK, I don't want to do it cheaply at the same time. Ugh!! I just don't see how using the bed rarely and having a cover that there would be future problems but if I'm going to spray in the bed I want to do before buying a cover...
What about the outside, any tips here.. is this a DIY type of job?
Old May 19, 2011 | 05:50 PM
SLT8's Avatar
SLT8
Its up to you if you want to see the wear on the bed every time you open the cover. If you can deal with it then don't. Easy as that.
Personally i would do a Bedrug w/ a Tonneau cover. Ran that setup for years and was great.
Feel of a big "trunk" and i still hauled garbage/debris/dog food. Quick vaccum wash and it was good as new. Ran this for 4 years until i wanted to do some weight reduction so took the cover and bedrug off and had it lined over the rails for $250.
Old May 19, 2011 | 05:56 PM
T_Visk's Avatar
T_Visk
I can handle the look, just worried about future problems really. But ya, I might pass.. I just don't want to open it one day and see a hole in the floor or something..
Is there any options for the rails so they dont get scratched up besides liner?
Old May 19, 2011 | 06:08 PM
SLT8's Avatar
SLT8
If Rams are popular in your area then you maybe lucky and strike up a whole bed if some one is parting on your local CL or check out the local salvage yards. Maybe save enough to offset the need for liner and bed cover.
Old May 19, 2011 | 08:21 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, I have a spray in liner and a cover. The spray-in keeps my stuff from sliding around.
