2004 Dodge Ram 1500 IPM/PDC/Fuse Box
Old Jun 28, 2011 | 11:13 PM
Richie Unuk's Avatar
Richie Unuk
Default 2004 Dodge Ram 1500 IPM/PDC/Fuse Box
I am looking for a IPM/PDC for my Truck. Does anyone know if one from an 05 will fit one from an 04? Both are gas vehicles.
Old Jun 28, 2011 | 11:31 PM
Owensue's Avatar
Owensue
02-05 should work for you.
Old Jun 29, 2011 | 09:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. As said, 02-05 will work. I dont know of any trucks currently getting parted out but check around on various sites or even Ebay and Craigslist.
Why do you need one BTW?
Old Jun 29, 2011 | 01:26 PM
Richie Unuk
My tail lights are not working, fuses/bulbs are OK. Done the continuity test thru the IPM that controls the tail lights, and it shows an open circuit. I guess the control board is prone to corrosion. Dodge knows this and has installed a splash guard underneath where the wiring harnesses plug in. No recall, and they want $600 for the new part. I wanted to know what year of trucks used this same part, or are they specific to each year.
I heard that the wiring harnesses are different between an 04 and 05.Wanted to get some feedback.
Old Jul 4, 2011 | 07:00 PM
Owensue's Avatar
Owensue
I repeat!!
Old Jun 13, 2014 | 04:14 PM
pen101's Avatar
pen101
Default same problem....
No plate lights ...no tails....not even front markers....got to be a "workaround"....600 bucks for a new board...ouch!
Funny everything else works (gonna check the daytime runners now)...
I'm with buddy a reply would be nice, a schem of the wiring on this part...nicer....how to get those clips off from underneath....NICE"EST?
Old Jun 13, 2014 | 04:15 PM
pen101's Avatar
pen101
Forgot...thanks all for at least looking!
Old Jun 13, 2014 | 04:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Take the PDC off and out and inspect the harness plugs and connectors. If it looks good, take it apart and inspect it. If all else fails, you can buy a used one off eBay or such
Old Jun 15, 2014 | 08:34 AM
pen101's Avatar
pen101
yep looks like cannibalization is about the only feature left open to me, popped off the relay to check for power, relay looks burnt (blue tinge to prongs) and what I think to be the power inlet for the relay (the one closest to the headlight) looks like it fried.
So I am guessing FCM, PDC and back light circuit boards with ground checks to all wires related.
I do not use the truck a lot, my own construction jobs, hunting etc. When running during the day, no problems, daytimes works (front) signals and brakes.
I looked at ebay, matching numbers on the FCM, obviously Canuck truck, USA parts...if I buy used, I may be buying the same problem (if this is a common problem) and buying new...at least here looking at a easy "G" plus my day for a install.
I replaced all the bulbs in the back because I had one tail light out last summer, figured do them all because I had no rev lights, never fixed that.
Besides daytime runners, can I use USA truck parts or will there be a difference?
Maybe just buy a other truck...one with the lights working.
Mine is a ST..reg cab 4x4, 5 spd man, 4.7.
Bought her in 2012...was cheaper than most trucks of the same age I was looking at...maybe I know why?
Again Thanks
