Are gps units accurate to check speedo?
Old Jul 4, 2011 | 09:53 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by bigdaddyII
I went from 265s to 285s and read here and other places that this would make my speedo 2 miles or so slower then my actual speed. I had to see for myself as every vehicle/situation is different. I checked first with the GPS on my phone and at 60 it said I was going 62. I checked next with a Tom Tom and it read the same, so I adjusted accordingly. After passing a mobile radar unit that the police put up it said that at 60 I was going 60, so I repeated both previous checks with GPS as well as borrowing a co workers Garmin and they all read the same, 2 mph over. I'm not going to go out and spend money on either a programmer or the dealer to calibrate it for 2 mph so I just adjust my speed. If I needed/ wanted to see actual sppeed all the time I would buy another GPS and leave it up all the time.
+1 Once you know the error, it's not necessary to spend money to compensate.
Old Jul 5, 2011 | 10:26 AM
Cthulhu's Avatar
Cthulhu
..if that was true it would keep a lot of big tires and lift kits off trucks around here.
Old Jul 5, 2011 | 10:43 AM
HammerZ71's Avatar
HammerZ71
NO TIRE is the exact height listed on the sidewall (and very few are true to the "listed" specs either). MY "35x12.5x17" Cepeks measure just a hair over 34 1/4" when filled to the max. air pressure as on the side of the tire. More like just barely over 34" when I run them at 40 lbs. (max is 50).
Measure them by hand and plug in that diameter and the GPS will be just about dead on...
Old Jul 5, 2011 | 06:45 PM
MikeHTally's Avatar
MikeHTally
Why? My speedometer reads 76 @ 80. All I need to remember...
Old Jul 5, 2011 | 08:31 PM
lxman1's Avatar
lxman1
Site Moderator
You driving more miles than your odometer is showing. I'm calling the NTSB and reporting you right now
I have found that the mobile radar machines on the side of the road are quite inaccurate. My speedo is dead on and it shows me a few mph slower than I am really going. My Mustang reads about 3mph higher than actual speed, yet the roadside radars show me going the speed on my speedo.
