Are gps units accurate to check speedo?
Old Jul 3, 2011 | 08:36 PM
2005DodgeRamDad's Avatar
2005DodgeRamDad
Default Are gps units accurate to check speedo?
I had been trying to flash my speedo on my 2005 Ram and can't seem to get it right. I went from p245 to p265. The Michelin website said my LTX MS2's are 31.7" diameter. I set it at 31.75". That wasn't close so I entered 31.5". It is accurate at 40mph but is GPS'd roughly 2mph under the speedo at 60 to 90mpg.
Is calibrating it to the GPS accurate?
I am taking a road trip and want an accurate speedo.
Old Jul 3, 2011 | 08:41 PM
Cthulhu's Avatar
Cthulhu
I'd say they are as accurate as you or I could ever get. When you can have 3+ units all showing a gps speed of the same result, that's closer than any cop will ever be able to prove.
Old Jul 3, 2011 | 08:44 PM
2005DodgeRamDad
So should I ignore the tire diameter from the manufacture and adjust the tire size on the programmer until the speedo matches the gps unit?
Old Jul 3, 2011 | 08:49 PM
MikeHTally's Avatar
MikeHTally
Absolutely. The Garmin "phones home" every six seconds and is accurate to within ten feet. Presumably, they all are similar. That is how I learned my Ram is 4.3% off (low) with the 285/70s. Making that adjustment will also correct your odometer.
Old Jul 3, 2011 | 08:54 PM
lxman1's Avatar
lxman1
Site Moderator
GPS is correct. Just play with the size until it reads right @ 60mph.
Old Jul 3, 2011 | 09:10 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by lxman1
... Just play with the size ...
I thought this was a family forum!
Old Jul 4, 2011 | 12:43 AM
2005DodgeRamDad
That would be distracted driving! In all seriousness, thanks for the posts. I will adjust the diameter until it reads correctly. Ialso have a Garmin.
Old Jul 4, 2011 | 02:15 PM
BlueRam06's Avatar
BlueRam06
my garmin is deadone in all 3 vehicles so i would say they are very accurate.
Old Jul 4, 2011 | 02:39 PM
Matt99's Avatar
Matt99
My truck is like 15ish off at 70, so I have to keep a garmin in the truck just to know my speed. I guess I need to order a programmer one of these days
Old Jul 4, 2011 | 08:59 PM
bigdaddyII's Avatar
bigdaddyII
I went from 265s to 285s and read here and other places that this would make my speedo 2 miles or so slower then my actual speed. I had to see for myself as every vehicle/situation is different. I checked first with the GPS on my phone and at 60 it said I was going 62. I checked next with a Tom Tom and it read the same, so I adjusted accordingly. After passing a mobile radar unit that the police put up it said that at 60 I was going 60, so I repeated both previous checks with GPS as well as borrowing a co workers Garmin and they all read the same, 2 mph over. I'm not going to go out and spend money on either a programmer or the dealer to calibrate it for 2 mph so I just adjust my speed. If I needed/ wanted to see actual sppeed all the time I would buy another GPS and leave it up all the time.
