Would like to get 285/70 R17 is it worth it?
I am currently running the 265/70 R17's. I would like to get something a little taller that will fill up a little more of the wheel wells, but I would like the height to be the same as width. I have the 2" spacer in the front to level the front end. So I was wondering if the 285/70 R17 would accomplish this. I dont want to go to drastic I am also looking to convserve fuel mileage too. And I know the bigger the tire the more fuel it will take to turn them. I want to say there is a 3.5" gap now between the tire and fender but don't quote me.
The tires I am looking at are the GY Wrangler Dura Trac
Thanks for your input.
265/70 R17 is it worth upsizing?
In the 265 series for the GY I see they are load range E which I would like to stay with. I wanted a more ply tire since I tow alot and I am going to be putting a plow on. When I looked up the 285 series they are only in the D range so not sure if I want to go that route because of the load range.
I never thought buying tires would be such a P.I.T.A!!
on
I would not put a Duratrac tire on a full size 1/2 ton QC truck, so on a 3/4 ton ain't no way.
This tire is the staple of the Jeep crowd but everybody recognizes that it has a weak sidewall (yes even in an "E" load range). Lots of documented cases of sidewall failures on heavy trucks. Once the vehicle gets up over 5000 lbs. this tire starts to get out of it's element. It's basically a GREAT mid-size 4x4 SUV or smaller pickup tire but not a good heavy truck tire.
There are a LOT better choices out there, probably a good bit cheaper in an "E" tire in basically a 33" x 11.5" (285/70/17) tire.
Normally I'd say a "D" is fine, the rating is still higher than the rated capacity of a 1500, but with a 2500 and your intended use, I'd go with the "E" load...
My 2500 Megacab has that size tire on it. Click on my garage link to see photos of the truck. All the mods and such were done by a previous owner. I believe there was a leveling kit installed, and it has airbags in the back. Not sure if it gives a lift, but with this setup my truck sits a bit higher than other 2500's I've parked near. Compared to the original 265 spare, the tire is about 1 inch higher and a bit wider as well. The tires don't rub or anything. But, I also have after-market rims which may have different spacing to the factory wheels. The tires are BFG All-terrains. I don't run heavy loads so Load rating isn't much of a problem. My heaviest load is when I tow my RV and the quad is on the box of the truck. Maybe 1200lbs maximum on the truck. Since I used to do that with a 1500 and P-rated tires, any LT is an improvement.
Is it worth it? No idea. I never ran the original size tires/wheels on this truck to compare. Looks decent with the suspension height on the truck. I probably never would of gone that route on my own, but that's just me. I usually just stick with what is on a vehicle...if it works don't change it type of thing.
I just changed up to 285's myself, BFG A/T's with a load range E. I have a leveling kit, but you can surely fit them without one.
The overall look I love, which was the main reason for the upgrade. But, one thing that I am complaining about is the large change in shifting. With a slightly larger tire, I knew my speedo was going to be off as well as shift points, but I was not expecting quite such the drastic change (not so much the speedo, but the shifting). I guess it is time for one of the tuner gadgets to get everything straightened back out.
Oh, and it is hard to tell right now with the speedo being off a little, but I am pretty sure I have dropped a full MPG (coming from 265/70/17E BFG Rugged Trails).
I can post up some pics some time if your interested.
Is there anything that has that same tread pattern and Load E in a 285?
Thanks
Trending Topics
i don't know how many people actually look at the sidewall number of plys on their tires, but between a D and an E rating tire the sidewalls both have the same number of plys, it's the number of plys in the tread that changes. i'd compare those with a LT tire and see what the sidewall ply is. do the same with manufacturer as well. compare a goodyear D rated tire with a gy E rated tire.
