Egr valve
Old Dec 13, 2011 | 10:13 PM
nsangueza's Avatar
nsangueza
Default Egr valve
Check engine light came on a couple days ago. Got the code read and it said EGR valve failure. Removed it, used carb cleaner and managed to clear most of the carbon I could. Reinstalled with new gaskets and seals. Engine light still on. Any advice?
Old Dec 13, 2011 | 10:35 PM
reefguy89's Avatar
reefguy89
did you reset the computer. Believe its disconnect the battery and pull the fuse for the ecm. i think its like 33 or 35 but im not to sure have to check.
Old Dec 13, 2011 | 10:38 PM
nsangueza's Avatar
nsangueza
I'll try that. In the owners manual it says it may take driving it around for the truck to realize it no longer has an issue. Thanks for the info. I'll look into the fuse#
Old Dec 13, 2011 | 10:49 PM
reefguy89's Avatar
reefguy89
you should reset the computer after you do any thing like that even after a tune up (spark plugs, sensors throttle body cleaning.)
Old Dec 13, 2011 | 11:04 PM
nsangueza's Avatar
nsangueza
Thanks a bunch man. Just did it, light is off. Hopefully it stays that way!
Old Dec 13, 2011 | 11:24 PM
reefguy89's Avatar
reefguy89
if it comes back on might be time to replace it.
Old Dec 14, 2011 | 05:57 AM
HammerZ71's Avatar
HammerZ71
I've never had much luck cleaning one, best I've ever done was to buy about a month without a CEL. For the $30 bucks they cost in the auto parts store, I'd just replace it...
Old Dec 14, 2011 | 06:58 AM
nsangueza's Avatar
nsangueza
Please excuse the ignorance but what's a CEL?
Old Dec 14, 2011 | 07:42 AM
HammerZ71's Avatar
HammerZ71
Check Engine Light
Old Dec 14, 2011 | 09:15 AM
nsangueza's Avatar
nsangueza
Ha. Of course. Thanks for the info.
