Magnaflow Y
Which specific Y-pipe do we need? I am on summitracing looking right now. I am just going to run single 3" exhaust with a Flowmaster 50 series.
This is the one I think I need:
http://www.summitracing.com/parts/MPE-10778/
I am considering this swap as well. I already had a shop make me a custom in front of the tire cat back. Basically the cut right behind the muffler or resignator (cant remember which was closer to the cab) and welded in a single in/dual out muffler. Have duel out one side in front of the tire.
Can I still install the Y? Do you keep the cats with the Y? To install is it nothing more than just splicing the Y into whats already there?
Maybe I'm not that bright. Is the restrictive part of the stock exhaust directly between the Cat and the manifolds? That's what it sounds and looks like. I just need to know prior to cutting this off and adding the Magnaflow.
From what I've read it's the crimping on the stock setup that sucks. My pipes coming off of the actual manifolds do not have any crimps in the bends.
