Post you aftermarket 20" wheels with 2" lift
I don't have any but here are some sites with the XD Addict wheels.
-http://www.cumminsforum.com/forum/20...hatever-4.html
-https://dodgeforum.com/forum/4th-gen...it-pics-3.html
-http://www.355nation.net/forum/wheel...me-decide.html
-http://www.ramforumz.com/showthread.php?t=52343
Here is my setup (and yes like mentioned above) they are 20x9 Fuel Hostage, 4.5" backspace (-12 offset), and the tires are 305/55/20 Nitto Terra Grapplers. They are a 33" tire but wide. Ill pose pics of both with and without my fender flares so you can see how far they stuck out. I alos have a 2" leveling kit only. They do NOT rub anywhere.
looks good, but its super important for me to know what offset I need to clear my control arms? With your -12 offset, it clears good? I dont like my spacers becuase of the little wobble, so I want offset wheels to avoid them, I need 1.5" spacers and they just clear it and thats max width I want to go regardless.
Trending Topics
How much -offset your going to need is going to depend on how wide of a tire you want to run. The stock offset is a +19 and I went to a -12 which is a difference of 31mm. 24mm = about 1 inch. So going from a +19 to a -12 spaced the wheel out about 1.25". Ive got a 305 tire on there and they dont rub. I know I could get a true 12.50 tire on there and probably a 325 without rubbing.
Basically how wide of a tire do you want to run? Do you want to worry thats its going to be splitting hairs close or have enough room not to worry about it?
