high mileage survey
Old Dec 30, 2013 | 08:29 AM
  #111
PRF66's Avatar
PRF66
What die in Wyoming ? How picking exotic mushrooms. Man I got 89500 miles on my truck and I never had a vehicle this long. All maintenence is performed on a regular maintenence interval from Trans to diffs to transfer cases to rotation to alignment to Mobil 1 oil changes.
Truck looks like new and runs like new. Then of course 89,500 is not all that much these days. Back to getting stuck in Wyoming......Man you don't want any part of a breakdown in Essex county people are kindly here, they will help you remove the tires and rims although they don't tend to bring them back.
Old Dec 30, 2013 | 09:58 AM
  #112
TheFist's Avatar
TheFist
Originally Posted by clifford the red dodge
You guys would die if you had to drive and work on your own truck anyplace rural.dont move to wyoming... any truck needs work on a regular basis. I put 25,000 miles a year, easily on any truck, of course some things will wear out. If the engine knocks, however, I would figure out why, and fix it, not keep running it till I was stranded 100 miles from the nearest town on a high mountain road. But that is just me... I dont drive till it blows, I do real maintenance on my truck, and when I am way out in the back country, I am confident I will get home...
You're making a pretty broad and ignorant assumption. My truck does quite a bit of off road use. My job requires it at times and I am also an avid bowhunter and my truck sees a lot of use on nasty washed out and rutted forest service roads and two tracks. I also tow a fair amount with it. As I've said before, the engines seem to be solid but everything else seems to be of a cheaper quality and doesn't hold up as well as other trucks. That's just the way it is.
Old Dec 30, 2013 | 11:24 AM
  #113
dirtydog's Avatar
dirtydog
Moderate User
I already know why. You just skipped past...
Originally Posted by dirtydog
Main one yea..
Hemi KNOCK, wouldnt exactly call it a tick. Fu>ker knocks. Started ticking at 400miles and got louder and louder. I have lifetime waranty so I'll run it till I sell it or until there's a problem. No way I'm letting a mechanic tear apart a bone dry engine to replace the exhaust valves. I'll prob have nothing but problems after.
My Rack is leaking at the bellow
It shimmy's terribly every now and again on the highway. I think it's tierod(rack) related
Had a bad Cluster
Stock battery only lasted 3yrs
bumpers are rusting a fairly good amount on the backside(truck has been washed everytime it touched salty roads..yes I spray under and behind bumpers. Not a spec of rust anywhere else)
Just typical Dodge Ram issue's. I never had my hopes set high for this truck. It was the cheapest truck pricewise and proves to be so quality wise as well. I'm just glad I use it sparingly. It's still the sharpest truck for the year and I still like it over other brands. I haven't been let down because my hopes were never super high..lol
and I'm 5miles from my dealer. I have AAA and it passed the 5yr Lifetime Warranty Inspecton. So, yeah, I'll run it till it dies if I have to before letting them open up a dry engine. It's only the valve guides. No big deal.
Old Feb 18, 2014 | 12:38 AM
  #114
Insaino's Avatar
Insaino
Old Feb 20, 2014 | 10:47 AM
  #115
Easy_e's Avatar
Easy_e
My 2007 Dodge Ram 1500 QC Hemi only has 259K miles and runs like it's new.
Old Mar 16, 2014 | 08:21 PM
  #116
bfuller14's Avatar
bfuller14
I have a little over 300,000 on my 96-3500
Old Mar 17, 2014 | 09:26 AM
  #117
TheFist's Avatar
TheFist
Gas or diesel?
Old Mar 18, 2014 | 10:32 AM
  #118
bfuller14's Avatar
bfuller14
5.9 Diesel
Old Mar 21, 2014 | 03:55 PM
  #119
Easy_e's Avatar
Easy_e
On my way to work today...
Old Mar 22, 2014 | 12:33 PM
  #120
TheFist's Avatar
TheFist
Nice. I hope mine stays together like that.
