Suspension upgrades?
Old May 14, 2012 | 02:26 PM
gHEMImorePower's Avatar
gHEMImorePower
Hammer I think we've talked about body lifts before somewhere. Do me a fovor please, can you post a pic of your truck completely from the side? Not angled but actually looking at the side. I want to see how much room you have in the wheel well/ fender area
Old May 14, 2012 | 05:50 PM
HammerZ71's Avatar
HammerZ71
At roughly $400 for a PA 3" body lift I wouldn't call that expensive since the Rancho 4" suspension lift is around $2000 with shocks. I thought seriously about adding a 3" BL some time ago but since I won't put more than 35" tires on an IFS truck and the fact I use my bed a lot, coupled with the fact that because of the winch mounted to the frame a LOT of fabbing would have to be done, I decided to stay right at 4".
This is the same 4" of lift you have with 35"x12.5"X17" tires, although since I'm a torsion front and you're a coil front, the lifts are a bit different:
Old May 14, 2012 | 06:08 PM
gHEMImorePower
What I meant is I wouldn't like the bl on my truck cuz I'm not going bigger than 35's. With 7" lift 37's are a have to. Now that I've seen yours I'm happy with how it will look. Anyway while we are in the classroom, what type of differential should I go with? Limited slip or automatic locker? What's the difference between those and my stock diff?
Old May 14, 2012 | 06:09 PM
gHEMImorePower
Beautiful ram btw!
Old May 14, 2012 | 06:34 PM
reefguy89's Avatar
reefguy89
theres nothing wrong with 37's. i love mine. Actually once i get my bodylift 40's will be going on.
Old May 14, 2012 | 06:35 PM
reefguy89's Avatar
reefguy89
i believe are trucks stock are already limited slip diffs. Most guys upgrade to a locker like a detroit.
Old May 14, 2012 | 07:24 PM
HammerZ71's Avatar
HammerZ71
I've seen too many IFS trucks snap CV axles with 37s, couldn't imagine being able to support 40s. That's definite SFA territory, but good luck with it.
About 60% of the 3rd Gen 4x4s shipped with LSD, but it's a very poor LSD, even without the broken clip issue, it doesn't perform very well.
If the truck is a daily driver, LSD is the best bet, either an Auburn or Detroit TruTrac. For more of a weekend truck a locker is fine, but they ratchet pretty severe when turning on pavement. Obviously a locker gives better traction, but most guys I know who have put them in daily driver trucks have ended up taking them out because of how undriveable they are on pavement.
A selectable locker is the single best solution, but they can run close to a grand in price and if someone makes one for the 9 1/4" AAM rear end, I'm not aware of it. Again, these are things made for SFA trucks with 10.5" and larger axles...
Old May 14, 2012 | 07:48 PM
reefguy89's Avatar
reefguy89
Yea i know what im getting into. if it breaks ill fix it. hopefully with bigger stonger parts.
Old May 14, 2012 | 08:12 PM
gHEMImorePower
Yea that's what's wrong with running 37's. I love 37's but a dodge 2500 is really the best all around truck for lifts, big tires, and offroading, not a 1500. And about the differential sorry I don't know what I was thinking. I know I got the lsd (what's bad about it btw?) I meant to ask about automatic vs selectable. I've never heard of a selectable locker for anything other than a jeep or something small like that. Would a better lsd help me offroad much? Cuz they're typically not great offroad
Old May 14, 2012 | 08:14 PM
gHEMImorePower
And Hammer, would purchasing a stronger cv axel be enough to run 37's? Sorry bud you're getting bombarded by questions here!
