Best Leveling Kit
Old Sep 23, 2012 | 04:26 PM
AODell5's Avatar
AODell5
Default Best Leveling Kit
I have my 02' Dodge Ram quad cab 2wd 4.7L V8 and i am wanting to put a leveling kit on it to even out the front end so it doesnt slope. i was wanting to ge suggestions on kits for and i find out the best deal for it. and also i am lookin into putting some Nitto Grapplers on my truck. anyone whos got Nitto Grapplers on their truck or if you have had them before then any talk is welcome any suggestions would help, i appreciate it.
Old Sep 23, 2012 | 07:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 3rd Gen Ram section.
Old Sep 23, 2012 | 07:48 PM
HammerZ71's Avatar
HammerZ71
The 2WD guys will weigh in on lift options, but if you're thinking just coil spacers here then IMO a puck is a puck and there isn't a real difference between brands.
As for the tire choice, I had a set of Terra Grapplers on a lifted Grand Cherokee I owned from '06 until just a couple of months ago. In an A/T tire they are a great choice. Very good to excellent performance in any environment I ever had them in except deep mud - but then again - no A/T tire is gonna be great in heavy slop. Probably the best wet pavement tire I have ever owned...
Old Sep 23, 2012 | 11:06 PM
zowen51's Avatar
zowen51
New Member
i got my leveling kit from autoanything.com for pretty cheap, it's truxxx brand and look really good and have had no problems. make sure you get your front end alignment after getting the level kit installed though
Old Sep 24, 2012 | 10:01 AM
AODell5's Avatar
AODell5
thanks yall i appreciate it much. Zowen do you have any pics of your truck? and did you have the leveling kit installed or did you do it your self? just curious on how much it would be around for parts and labor.
Old Sep 24, 2012 | 01:57 PM
08HEMI1500's Avatar
08HEMI1500
You can do it yourself as long as you have all the right tools and it can be done in a couple of hours form what I've seen. I'm not too sure on the pre 06s for leveling as the suspension set up is a little bit different since we have coil front suspensions but for the 06 up the best route is lift spindles but I don't think you have that option. Maybe longer springs?
Old Sep 24, 2012 | 05:31 PM
AODell5's Avatar
AODell5
I honestly need to replace my shocks on truck, so im figuring I may just go ahead and replace my Shocks and springs on top of leveling it out. Do y'all use auto anything quite a Bit to order parts? Or is there something better out there?
Old Sep 24, 2012 | 09:00 PM
ewing111's Avatar
ewing111
Autoanything is good, as is rockauto. Amazon and ebay are worth a shot although leas reliable.
Old Sep 25, 2012 | 10:04 AM
SpecialEdJon's Avatar
SpecialEdJon
If your going to replace your shocks and coil springs best thing is to get the rough country 3" coil springs with ther shocks. thats what i did. I think it was about 75 for the springs and around 110 for all 4 shocks.
