exhaust mess
Ok well i just went and had a 2 in one out 50 flowmaster with tips put on my 2008 ram and it sounds great but i noticed that i lost power and it won't shift down or up on time it seem like too much of a coincedence for this to happen but i went and had trans flushed and changed the filter but still sluggish anybody before i put it back i also reset the com by disconnecting the batt. It also is not throwing codes my girlfriend drive it and Sais the same thing
![Smile](https://dodgeforum.com/forum/images/icons/icon7.gif)
What you did should have no affect on the performance of your truck. I think you mean a 1 in 2 out muffler since the other way you would only need one tip. I'd be looking elsewhere if you can actually feel a performance difference, from a new muffler. I had a 50 flow on my 06 for a while and it ran as good as any muffler I ever had on it, and no shifting issues at all. Did you remove the cats and the resonators at the time you changed to the flowmaster? Losing that much back pressure at one time might have a poor performance feeling, but if you left all that stuff in place it should not have made the truck feel sluggish.
![Wink](https://dodgeforum.com/forum/images/icons/icon12.gif)
He said he had tips, so I figured he just made a misquote. As far as your statement I agree 100% but if a muffler shop installed it backward after seeing a 3 inch pipe for the inlet they need to be out of business. Until coming to this forum I had never heard of disconnecting the battery before welding the exhaust, and have had it done many times without frying the PCM
Yes one in two out and i am of the same thought should not affect the performance but it did i took out the
Resaniator but let it stock fine the cat back it is the oddist thing i ever saw but i had teams filter change and flushed also reset truck i have obd2 showing nothing just pcv code then it will go away after three heat cycles without Mr resetting it.could they have fried a ground just had way more pep. I MISS MY HEMI.
At the dealership we had a new tractor run then die, run for an hour then die, not shift then shift by itself without being told to do so. Turns out it was left outside during a thunderstorm. We figured it was struck by lightning, replaced the ECU and it was fine.
Hopefully your PCM is OK. Good luck.
