Homemade oil seperator
Old Apr 7, 2013 | 02:29 PM
Blacksport's Avatar
Blacksport
Default Homemade oil seperator
After researching online and this forum, I decided to go ahead and make my own oil separator. I looked at buying a BT or Moroso catch can, but the way our PCV system is set up, I decided to go this way. I spent about $50 at Home Depot to get my supplies. I bought an oil separator, hose, and some fittings and voila, my truck has an air/oil separator system.
Old Apr 8, 2013 | 10:33 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Specs? I'm trying to find fittings for my Lowes separator...
Old Apr 8, 2013 | 11:12 AM
Blacksport's Avatar
Blacksport
Well, it depends what size the connections are on your filter. Mine was 3/8 NPT. So I had to use a 3/8 x close nipple, then a 3/8 to 1/2 adapter to connect the hose.
Old Apr 8, 2013 | 11:15 AM
Izero's Avatar
Izero
Wonder how well it will work.... as the Automotive Oil is a bit heavier than air compressor oil generally so it might get clogged up pretty quickly....
Keep us posted on how it works out, I am curious.
Old Apr 8, 2013 | 02:58 PM
Blacksport's Avatar
Blacksport
It is 5W20 fully synthetic, so it might not be an issue. But I will keep you guys posted.
Old Apr 9, 2013 | 10:24 AM
dodge dude94
I think mine is 3/8 NPT. I've been having to do research on the different fittings.
My hoses are 3/8 SAE, so will the barbed fitting fit on the 3/8 hose?
Old Apr 9, 2013 | 12:27 PM
Blacksport's Avatar
Blacksport
Yes, as long as the ID of the hose is 3/8
Old Apr 18, 2013 | 04:14 PM
DirtyDodge812's Avatar
DirtyDodge812
how is this working out? did you see any results yet?
Old Apr 19, 2013 | 02:36 PM
Blacksport's Avatar
Blacksport
I haven't taken a close look at it yet...probably won't see anything for a few thousand km's. But I will keep you posted. I'll take a look in a coupe of weeks and let you know what's in there(if anything!)
