Better MPG and Better Performance
Old Jun 30, 2014 | 06:33 PM
plus4's Avatar
plus4
Default Better MPG and Better Performance
I have tested different setups and i have found a way to increase mpg out of dodge products. the best results come from the v8's (5.2,5.9,4.7 & 5.7) you can use this application in v6's (2.7,3.5,3.6) but not as good in result.
i have a 2003 dodge ram 4.7l v8 and i currently get 20 mpg http://www.fuelly.com/car/dodge/ram_...3/plus4/206717... and i haven't lost horsepower or acceleration my best is 23 mpg. its simple process to get more horsepower and mpg.
all you have to do is reduce the load on the motor. my normal load is 4% at start-up and at warm 3% normal city driving 5% to 8% load. freeway 12% to 16% load.
(you can monitor your engine load and real time mpg and your average miles by using ScanGauge below picture)
Normal air filter system is designed to reduce air intake, a cold air intake can rob you of mpg if you don't watch your foot on the pedal. You can take off the normal air filter system back to the Resonator (in-front of your throttle-body if you wish you can remove it but you gain more mpg keeping it on) replace it with a microfiber cloth.
In City i Shift at 1000 to 1500 RPM, On freeway i shift at 1500 to 2000 RPM.
Also if your dodge has 20" inch rims those rob you of 3 to 4mpg easy it adds alot of rolling resistance.
http://www.cardomain.com/ride/403684...00-regular-cab my current setup on ram
Keep:
Resonator
Remove:
Upper cover Air Box
Air Filter element
Lower cover Air Box
Air cleaner hose
Replace with:
MircoFiber Cloth 75/25 Blend
(continue reading about microfiber http://www.ercwipe.com/benefits-of-microfiber.html )
Paper (cellulose) - Most common (below).
May clog faster than synthetic. Will expand and restrict flow when wet.
Oiled Cotton - K&N and others. (below)
Better flow, less filtering.
MicroFiber (below)
Better airflow and filtering. The revolutionary technology and effectiveness of the microfiber lies in the construction of each strand. Each microscopic strand of microfiber has been split, creating millions of tiny hooks that attract, absorb and remove all kinds of dirt, dust and bacteria. Each strand of fiber is shaped like a wedge, trapping the dirt until it is washed. Since the dirt gets trapped in the fibers, the same microfiber cloth or mop head can be used for a longer period of time cleaning larger surface areas before having to be laundered. Each square inch of microfiber contains approximately 90,000 fibers.
Attached Thumbnails Better MPG and Better Performance-plus4-280386-albums-2003-dodge-ram-21421-picture-ho-5018321-47183.jpg
Old Jun 30, 2014 | 09:00 PM
ok. thanks....
Old Jul 3, 2014 | 08:00 PM
plus4's Avatar
plus4
As of June 30th i was at this trip
Now i am as of July 3rd i am currently at
Attached Thumbnails Better MPG and Better Performance-plus4-280386-albums-garage-black-ram-21410-picture-20140630-191903-47177.jpg   Better MPG and Better Performance-plus4-280386-albums-garage-black-ram-21410-picture-20140703-194350-47178.jpg
Old Jul 4, 2014 | 06:42 PM
doncline55's Avatar
doncline55
i have and 04 4.7 getting 15 on hwy put on chip and a turbo wheel in my air pipe close to in take nothing changed
Old Jul 5, 2014 | 01:22 AM
plus4's Avatar
plus4
So you did a chip mod and added a turbo and did a air pipe? Can you please provide a litte more information or pictures
Old Jul 5, 2014 | 04:18 AM
Prismatic's Avatar
Prismatic
Is this a joke? Tell me this is a joke.
Old Jul 5, 2014 | 04:59 AM
plus4's Avatar
plus4
Its natural to be skeptic of this, why not try it. Got nothing to lose lol but I can understand being scared to try it.
Old Jul 5, 2014 | 07:52 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Aside from the second photo being blurred, what is it you're claiming, and where is the data that supports your hypothesis?
Old Jul 5, 2014 | 09:37 AM
RDuck's Avatar
RDuck
That many days and you haven't fixed your burnt out lamp or filled your washer fluid but you could afford cheese cloth to give better fuel mileage.
Cool.
So take off my system and install a cheese cloth. Hmm... nope.
Im scared. Ooooh scary. Lmao.
Old Jul 5, 2014 | 10:28 AM
plus4's Avatar
plus4
I used scangauge which monitors data in my "hypothesis",lol lamp and low washer fluid wasnt a concern to me.
