Dodge heads
Old Jul 22, 2022 | 04:39 PM
Donald Mays's Avatar
Donald Mays
Default Dodge heads
I have a 2002 Dodge ram 1500 5.9l gas engine with 220000 miles on it. The oil has been changed every 3000 miles on it. My question is it advisable to replace the cylinder heads on it with this milage.
Old Jul 22, 2022 | 04:43 PM
fj5gtx's Avatar
fj5gtx
Are you trying to fix a problem, or just looking to improve the truck? Factory heads tended to crack, there was a better and very affordable aftermarket cast head available - but I believe they have been discontinued, so they might not be as readily available as they once were.
Old Jul 22, 2022 | 04:56 PM
dodgetruck2's Avatar
dodgetruck2
I'd say don't go looking for a problem that doesn't exist, but the above post is correct. Oil changes a really no affect on the head itself, cooling and keeping the truck cool are what will effect that, definitely options still available but depends on what you want to spend, EQ offers a stock replacement that supposedly functions better than a stock head, trick flow makes a performance head (900ea ), I'm sure there's other options also
Old Jul 22, 2022 | 06:42 PM
Donald Mays
I am installing a rebuilt set of heads on the truck my question is with the milage that is on the truck will I be causing any other problems by doing this.
Old Jul 22, 2022 | 09:29 PM
Shouldn't be. Keep in mind though, the stock heads already had thin decks. That's what led to the problems. When most folks 'recondition' heads, one of the steps is to shave the mating surface, to insure it is flat, this only make the problem worse. Enter the new castings, with thicker decks.... Clearwater and Odessa cylinder head both sell 'em. They are the same company. Can generally find them on ebay for around 600 a pair.
Old Jul 25, 2022 | 07:50 AM
fj5gtx's Avatar
fj5gtx
Rebuilt heads were not much savings over new ones, not sure how the economics is working since covid. At 220k miles, I'd be looking at a full refresh - bearings, rings, fresh hone, etc. At minimum, replace the timing chain with a double roller - the originals tended to stretch.
Old Sep 1, 2022 | 11:54 PM
lxman1's Avatar
lxman1
Site Moderator
If the engine wasn't burning oil and had good oil pressure, before removing the heads, then there should be no issues with a fresh set of heads.
