Front and/speed sensor connection location
Old Apr 2, 2024 | 07:00 AM
3lowdown's Avatar
3lowdown
Default Front ABS/speed sensor connection location
2005 dodge ram 1500 2WD. Can't find the plug to plug in my right front wheel speed sensor wire. There's a two wire plug with the wires cut, but it is on the wire loom on the left side of the transmission. Is there an extension wire that goes from the left side of the transmission loom to the right front wheel?
Old Apr 2, 2024 | 08:01 AM
Do you have 4 wheel abis? Or just rear wheel?
Old Apr 2, 2024 | 08:23 AM
3lowdown's Avatar
3lowdown
Default Front wheel speed sensor
I think it is front and rear abs. The hubs I replaced both had speed sensors in them. And the left front has a wires that are plugged in in the wheel well. The right front wires were cut
Old Apr 2, 2024 | 08:25 AM
Is the ABS lite on? You can run your VIN here, and see if 4WAL is listed....
Old Apr 2, 2024 | 09:44 AM
3lowdown's Avatar
3lowdown
Yes the abs and brake light are on. That site said no records for my vin
Old Apr 2, 2024 | 02:32 PM
It is case sensitive, so, and letters have to be caps.
Old Apr 2, 2024 | 07:15 PM
3lowdown's Avatar
3lowdown
got it:
4 WHEEL DISC RR ANTI-LOCK BRAKES
Old Apr 2, 2024 | 07:22 PM
Rear antilock, so, there wont be a connector for the right front wheel.
Old Apr 3, 2024 | 08:24 AM
3lowdown's Avatar
3lowdown
thank you!
