O2 sensor code P0155
Old Sep 11, 2024 | 01:42 PM
Dhalas818's Avatar
Dhalas818
Default O2 sensor code P0155
I've had the sensor replaced along with the crank sensor on my 2008 Ram 1500 3.7 STX and the engine light comes back on for same code. Anyone else have this issue that can help me find the problem. Thanks!
Old Sep 11, 2024 | 06:08 PM
Which sensor did they replace? That code is for bank 2, heater circuit. Have you checked the fuses?
Old Apr 3, 2025 | 03:43 AM
Dhalas818's Avatar
Dhalas818
Default O2 sensor fuse
I did not see a fuse for the upstream sensor in my fusebox on 2008 STX 3.7L, am I missing something?
Old Apr 3, 2025 | 10:00 AM
What code are you getting?
Old Apr 3, 2025 | 01:43 PM
Dhalas818's Avatar
Dhalas818
Getting a P0155. I swapped the upstream O2 sensors and getting same code so I know the sensors a good so it has to be something else causing it.
Old Apr 3, 2025 | 01:52 PM
Did you clear codes before re-testing? That's a heater circuit code. I don't recall if all the sensor heaters are fed from the same circuit though....
Old Apr 3, 2025 | 01:57 PM
Dhalas818's Avatar
Dhalas818
Yes. Going to take it for a ride and see what pops up next. Shouldn't take long.
Old Apr 3, 2025 | 02:13 PM
Dhalas818's Avatar
Dhalas818
Just threw 3 codes. P0300, P1129, and P0152. This is aggravating to say the least.
Old Apr 3, 2025 | 02:45 PM
High signal from O2 sensor, bank 2, sensor 1. If you have already swapped the sensors around, time to check the wiring. Seems you have a short somewhere.
