New lights behind the grille.. whaddaya think?
RE: New lights behind the grille.. whaddaya think?
I drilled a 1/2 " hole in the crossmember in front of the radiator. I measured out 10 1/2" from the center drilled the holes on that cross member. That gave me 21 inches between the lights. I actually wanted 20 inches between, but there were some things in the way that prevented that.
ORIGINAL: Pirata
How do you have the lights mounted? Specifically the hardware/drill points.
[IMG]local://upfiles/58642/16D058F0F81D47E2BC194FB0E2D509D4.jpg[/IMG]
I put Hella 500s behind my grille. I wired them so they come on with the parking lights and with a switch to shut them off. I mounted the switch under the dash to hide it. I paid like $65 at Advanced Auto. The biggest pain I had was pulling the drivers headlight to get to the wiring. I really didn't like laying the extention on the bumper paint. I used tape and rags just to be safe.
ORIGINAL: oefootball_70
how do you run the wires from the hood to the cab? and have you ever installed the actual Mopar fog lights? I have black vented things instead.
I'm running the KC Daylighters.. And I love them.
