need help removing deck!
Old May 2, 2007 | 09:21 PM
Eckel's Avatar
Eckel
Default need help removing deck!
How do I remove the factory deck?
Old May 2, 2007 | 09:33 PM
HighDuke1911's Avatar
HighDuke1911
Default RE: need help removing deck!
go to the Audio/Visual Electronics section. habeba will be more than glad to help you out!
Old May 2, 2007 | 09:47 PM
HemiLonestar's Avatar
HemiLonestar
Unscrew the little screw behind the bag hook. PULL. Unscrew 4 bolts holding unit. Pull out and disconnect wires.
OR you could go download the factory service manual, which tells you in detail with picture how to do it.
Old May 2, 2007 | 10:23 PM
Eckel's Avatar
Eckel
Do you know how I get out the chord on the upper right side?
Old May 2, 2007 | 10:39 PM
hemiyellow's Avatar
hemiyellow
DC Insider
pull
Old May 2, 2007 | 10:42 PM
HemiLonestar
The antenna plug? Be very careful, you have to pull the little sleeve up first, then pull the plug out.
Old May 2, 2007 | 10:45 PM
Eckel's Avatar
Eckel
I have been pulling and pulling and it will not come out!
Old May 2, 2007 | 10:46 PM
HemiLonestar
Give it some torque, but just be careful not to yank the cable out of the terminal. I almost did. That would suck.
Old May 2, 2007 | 10:47 PM
Eckel's Avatar
Eckel
Yea I thinks it the antenna plug. I just wont come out
Old May 2, 2007 | 10:49 PM
Eckel's Avatar
Eckel
Do I take it outta the black thing? or do I take the metal peice that goes into the black thing?
