leveling kit
Old May 6, 2007 | 10:08 PM
d_b_wal's Avatar
d_b_wal
Default leveling kit
ok i have a 03 hemi 2wd quad cab. i have heard ups and downs about the kit on a 2wd. somw people say it will screw up the rack and pinion but im not sure. this is the first truck i have ever owend and do not have money for a full lift kit. i would be satisfied with the front leveled. if anybody has had done this please reply and let me know if it is ok to do and i wont be getting myself into trouble in the long run.
Old May 6, 2007 | 11:52 PM
txlee's Avatar
txlee
Default RE: leveling kit
Ive got an 03 quadcab 2wd with a4.7 i put on a rough country 6 inch kit. I put it on at 20 ,000 and now have right at 100,000 and have no problems. but i did get some internal extenders for my tierods with the kit. so it might make the diffrence.If this helps
Old May 7, 2007 | 01:20 AM
kvsmith2004's Avatar
kvsmith2004
I have a Daystar 2.5" leveling kit on my ram and works great. It was easy to install too. All I needed to get was longer shocks for the front and alignment.The 2.5" seems to bring the front up just a little bit more than the rear, so you can go with a 2" kit, or just get a block for the rear.
Old May 7, 2007 | 01:40 AM
kvsmith2004
Here are some pic's I just took. You can see how much more room there is in the front now, and there is a pic of a coil spacer itself.
[IMG]local://upfiles/27663/FCDFC3C2C4B8451A95ABAE3B61AA8EEA.jpg[/IMG]
[IMG]local://upfiles/27663/47F5FC9DC73D4647A646C363CFA1740C.jpg[/IMG]
[IMG]local://upfiles/27663/9B840CBEB22149B8A95C52661EE73645.jpg[/IMG]
Old May 7, 2007 | 11:13 AM
BTAL's Avatar
BTAL
Kvsmith2004 - what shocks did you use when you installed the Daystar? My understanding is that you the stock shocks aren't long enough? Thanks.
Old May 8, 2007 | 12:14 AM
kvsmith2004
The stock shocks are not long enough for the 2.5" kit. I went with a pair of rancho rs5000, I don't know what model number they are though. I will try to find the paperwork tonight. I would recommend getting another shock though, it is not any better than the stock shocks.
Old May 8, 2007 | 05:39 AM
d_b_wal's Avatar
d_b_wal
are the stocks long enough for a 2" kit
Old May 8, 2007 | 01:50 PM
nathanp's Avatar
nathanp
just crank your torsion bars all the way up and save yourself the money.... get the same results for free
Old May 8, 2007 | 02:04 PM
HuntinHanson's Avatar
HuntinHanson
ORIGINAL: nathanp
thats only 4wd trucks, 2wd hace coils up front
Old May 8, 2007 | 02:44 PM
nathanp's Avatar
nathanp
oh woops my bad missed that little bit of info haha
