Where are the head light fuses on a -04 quad cab 5.7?
Old May 15, 2007 | 04:04 PM
g_svan's Avatar
g_svan
Default Where are the head light fuses on a -04 quad cab 5.7?
I upgraded to bi-xenon--> and it works great The only thing is, I have to change the fuses to 20 amps, but I can't find them anywere... They don't seem to be in the fusebox... Any one???
Thanks for your help!
Old May 15, 2007 | 06:30 PM
helopilot's Avatar
helopilot
Default RE: Where are the head light fuses on a -04 quad cab 5.7?
Under the hood, drivers side, front corner.
Old May 15, 2007 | 06:54 PM
HuntinHanson's Avatar
HuntinHanson
^^^^ yep, exactly, theres a diagram on the bottom side of that panel to tell you which fuse is for what
Old May 15, 2007 | 07:05 PM
g_svan's Avatar
g_svan
I've looked in the fusebox! None of the fuses describe headlights. What numbers & descriptions(in the lid) does the headlight fuses have?
Thanks again
Old May 15, 2007 | 09:36 PM
kenihemi's Avatar
kenihemi
There is no specific headlight/headlamp fuse.
It is fuse #41 (foglamp) fuse.
That fuse feeds the fog lamp relay in the front control module and powers the fogs and heads.
Word of caution;
That circuit was designed for 15amps, so the wires are a little thinner and may burn with the extra 5 amps.
Old May 16, 2007 | 05:37 AM
g_svan's Avatar
g_svan
No, foglight and headlight is not on the same fuse... If I pull nr 41 fuse, only foglights go out
Old Sep 13, 2009 | 07:37 PM
jay8833's Avatar
jay8833
Default Relay or Fuse
I see the last post was in 2007, however I am re-asking the same question. Where is the fuse or relay for the headlights? I'm having weird light problems. For my headlights, only the passenger side low-beams work, then on high beams only the drivers side work and nothing on the passenger side. Also, when I put on the hazard lights, only the back passenger tail light blinks. I've checked every bulb with a meter. Any help? I'm thinking my fcm may need to be replaced. I've checked the notorious rear tail light circuit boards. They are fine.
Old Sep 13, 2009 | 09:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDK but I dont like the part where you say you need to change them to a 20a. If they are less than that (10a/15a) and you are blowing them and feel the need to go to a 20a then that is a bad idea. Real bad idea.
Old Sep 28, 2009 | 07:37 PM
jay8833's Avatar
jay8833
Update...i paid almost $300 to the dealership and replace the FCM but still have same problems. Does anyone know if you have to re-flash it?
Old Sep 28, 2009 | 08:54 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the power distribution box is bad. Holds all of the fuses and relays.
