Header Help
Old May 24, 2007 | 12:39 PM
morganmkelly's Avatar
morganmkelly
Default Header Help
I have two questions. Any help would be greatly appreciated. This weekend I will be putting on Ceramic-Coated Pacesetter Mid-Tube Headers while keeping the stock cats and Y-pipe. Is there a specific order in which I should tighten the bolts? Also, I'm running the superchips 91 performance mod with 93 octane. I have the CAI and flowmasters. With the headers, will I run too lean and is there a way to check my fuel to air ratio?
Old May 24, 2007 | 02:30 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: Header Help
for bolt tightening i usually go outside in, ex left outside then right inside back and forth. As for running to lean you shouldn't thats what the O2 sensor is for. I'd strongly suggest putting some locktite on the threads. Also if possible you should take a few pics of the install process to post up
Old May 24, 2007 | 03:10 PM
morganmkelly
Right on... Yeah, I'll definitely take some pics. And locktite - is that something I can find at the local Pep-Boys or Auto Zone?
Old May 24, 2007 | 03:21 PM
HuntinHanson
yep, all the autoparts stores should have it
Old May 24, 2007 | 05:29 PM
deanj287's Avatar
deanj287
mid shouldnt cause you to run lean. long tubes will though. your need a wideband af ratio guage. the whole set up is aroung 250 depending on where you get it
Old May 24, 2007 | 05:43 PM
morganmkelly
Can you exlpain to poor ole' white boy who quit school in the 4th grade what a widebandaf ratio gauge is and how it is used/hooked up/installed?
Old May 24, 2007 | 06:18 PM
deanj287's Avatar
deanj287
it adds another bung in the exhaust after the cat to determine the af ratio of your engine. it reads the same way the trucks computer does except it just shows you a read out with no adjustments. the kit you get (if you get one) will have exact install directions and everything needed
Old May 24, 2007 | 06:34 PM
sharpshooter's Avatar
sharpshooter
Locktite can your best friend or your worst enemy, if you never have an exhaust leak then you should be fine, if you havea gasket blow out you will be cussing whoever told you to put locktite on the bolts
Old May 24, 2007 | 07:24 PM
HuntinHanson
ORIGINAL: sharpshooter
lol locktite can be a nightmare, but don't curse me. I will never put something like that on without it. Just make sure to have lots of pb blaster and band aids if you ever have to take them out...
Old May 24, 2007 | 07:42 PM
nathanp's Avatar
nathanp
ORIGINAL: deanj287
why will longtube headers lean you out?? and how can u fix that
