Ethanol fuel??????
Old May 24, 2007 | 01:57 PM
Talltimbo's Avatar
Talltimbo
Default Ethanol fuel??????
Who has used it? Feedback please?
Old May 24, 2007 | 02:17 PM
Hemichief's Avatar
Hemichief
Default RE: Ethanol fuel??????
Your engine needs to beflex fuelcapable in orderto use it (the way the fuel is set up, will corrode some components unless they are made to accept the fuel). My Explorer had it and it burned nicer and actually gave more pep to the engine. The downside to it was my MPG decreased about 10%.
Old May 24, 2007 | 03:19 PM
Silver Eagle's Avatar
Silver Eagle
Everyone is using ethanol in there gas.Right now it's only ten percent ,but that's bad enough., my Mileage has dropped thirty percent since the oil companies have been using it. What gets me the most is Uncle Sam is paying them 51 cents per gallon to screw us.
Old May 24, 2007 | 03:35 PM
thunderace31's Avatar
thunderace31
You can put 5-6 gallons of it in with your normal gas with no issues in most cars and trucks (Per 18 gallon fill up) will save you a small amount of $$ and will increase performace we have tried it in all of our cars with no issue flex fuel and not. Long term effects I dont know about yet though everything seems to be fine.
Old May 24, 2007 | 03:44 PM
Talltimbo's Avatar
Talltimbo
I am talking about the E85 fuel. My 4.7L is E85 capable.
Old May 24, 2007 | 03:48 PM
thunderace31
Ya I was taking about E85 also
How do you know if it is or isnt Flex Fuel capable??
Old May 24, 2007 | 04:09 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
ORIGINAL: thunderace31
Inside the fuel door will be an E85 sticker if it is.
Old May 24, 2007 | 04:12 PM
Hemichief's Avatar
Hemichief
Also all E-85 fuel vehicles have it identified on their VIN. I am not sure what number it is or designator but they have it.
Old May 24, 2007 | 05:29 PM
Talltimbo's Avatar
Talltimbo
It says it on the back of the truck and the gas cap is yellow.
Old May 24, 2007 | 06:42 PM
Sir Hardin Thicke
ORIGINAL: Talltimbo
Not necessarily true. We have Dodge and Chevys at work that are all E85 and the Dodges gas caps are black. The Chevys are also black but have yellow lettering on them.
