Keyless locking
Old May 29, 2007 | 05:13 PM
zman2800's Avatar
zman2800
Default RE: Keyless locking
Well I too just took mine for the first oil change, and told them about not being able to do it. They said that the 07 had to be done with a programmer and wanted to charge 40 dollars to do it. I pointed out in the manual that it said I could do it so it must be broke and I needed it fixed. Walked away with it working and at no charge for it.
Old May 29, 2007 | 05:27 PM
morganmkelly's Avatar
morganmkelly
My buddy has an '07 and he got his turned off; he did it this way:
1. Get in vehicle, put seatbelt on.
2. Turn ignition to on without starting engine.
3. Release seatbelt button.
4. unlock doors to vehicle.
5. get out of vehicle and run around it three times at a counter-clockwise rotation with pink underwear over your head and a feather duster sticking out of your ***.
6. Repeat if necessary.
Old May 29, 2007 | 07:22 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
The seatbelt way was not what the manual that came with mine said to do. Mine just said to do the above steps without the ignition key nor the seatbelt.
Old May 29, 2007 | 07:32 PM
Erock509's Avatar
Erock509
This is from one of my old posts, hope this helps
--THE SYSTEM CAN BE PROGRAMMED TO UNLOCK ALL THE DOORS OR DRIVERS DOOR ONLY UPON THE FIRST UNLOCK BUTTON PRESS BY USING THE FOLLOWING PROCEDURE:
1. PERFORM THIS OPERATION WHILE STANDING OUTSIDE THE VEHICLE.
2. PRESS AND HOLD THE LOCK BUTTON ON YOUR KEY.
3. CONTINUE TO HOLD THE LOCK BUTTON AT LEAST 4 SECONDS, BUT NO LONGER THAN 10 SECONDS, THEN PRESS AND HOLD THE UNLOCK BUTTON WHILE STILL HOLDING THE LOCK BUTTON.
4. RELEASE BOTH BUTTONS AT THE SAME TIME.
5. THIS WILL ALLOW YOU TO UNLOCK ALL DOORS ON THE FIRST PRESS OF THE UNLOCK BUTTON.
---THE HORN CHIRP FEATURE WILL BE SHIPPED FROM THE ASSEMBLY PLANTS ACTIVATED. IF DESIRED THIS FEATURE CAN BE DISABLED BY USING THE FOLLOWING PROCEDURE:
2. PRESS AND HOLD THE LOCK BUTTON ON THE PROGRAMMED(I.E. FUNCTIONAL) KEY.
3. CONTINUE TO HOLD THE LOCK BUTTON, WAIT AT LEAST 4 SECONDS, BUT NO LONGER THAN 10 SECONDS, THEN PRESS AND HOLD THE PANIC BUTTON. RELEASE BOTH BUTTONS AT THE SAME TIME.
4. TO REACTIVATE THIS FEATURE, REPEAT THE ABOVE STEPS.
---VEHICLES WILL BE SHIPPED FROM THE ASSEMBLY PLANTS WITH THE PARK LAMP FLASH FEATURE ACTIVATED. IF DESIRED, THIS FEATURE CAN BE DISABLED BY USING THE FOLLOWING PROCEDURE:
2. PRESS AND HOLD THE UNLOCK BUTTON ON A PROGRAMMED(I.E. FUNCTIONAL) KEY.
3. CONTINUE TO HOLD THE UNLOCK BUTTON, WAIT AT LEAST 4 SECONDS, BUT NO LONGER THAN 10 SECONDS, THEN PRESS AND HOLD THE LOCK BUTTON. RELEASE BOTH BUTTONS AT THE SAME TIME.
Old May 29, 2007 | 07:43 PM
Pirata's Avatar
Pirata
The above one were the ones that were stated in the stuff I was given from my dealer when I bought my 2007. It could be that the 2007 does not work with these steps and I need to do the ignition switch/seatbelt to get mine to stop honking. Like I said I tried for about an hour using the above instructions so I am going to try the other and see what that does. If it does not work I can chock up another hour that I am pissing off my neighbors.
Old May 29, 2007 | 09:28 PM
Pirata's Avatar
Pirata
ORIGINAL: morganmkelly
You really had me going on that one...
Old May 29, 2007 | 09:33 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Pirata, an HOUR? You must not have small kids cause I ain't got that kind of patience.
Old May 29, 2007 | 11:16 PM
Pirata's Avatar
Pirata
Ok my neighbors are probably pissed off enough and I was not able to get it to turn the honk off. I was able to get it to open all doors from a single push of the unlock button.
Old May 29, 2007 | 11:23 PM
theHemiBeast's Avatar
theHemiBeast
You guys with 07's.....do you not read the entire thread???? It cannot be done without a programmer!
Old May 29, 2007 | 11:53 PM
go49ers's Avatar
go49ers
Thanks for the info on the 2006 model. For some reason my manual says you have to be in the car with the key lock in the on position and do the same steps you listed. That was obviously wrong. Thanks a bunch for the correct information above that you have to be OUTSIDE the truck.
Matt
