Dodge transmissions
Dodge transmissions
[align=left]I just bought my first Dodge truck so I don't know much about them. Its a 04 1500 with 20" wheels and a 5.7 Hemi. I have read quite a few post about transmission failures on some models. I do tow a trailer and have the tow package. So I guess I'm wondering if these problems are on other models or should I be concerned about the transmission. Which transmission would I have and is it a reliable one. I love the truck so far but I've always driven Chevy's in the past. I love the power of the hemi and it just seems like a well built truck all around just wondering about the transmissions. I'm just got it, read a several web sites with owners complaining about rebuilding transmissions 1 or 2 times and it concerns me. I'm new to this site so any information would be helpful. Thanks.
[/align]
[/align]
RE: Dodge transmissions
My 06 puked up a tranny at 6,000 miles. I blame modding it with a pcm programmer mainly but also at me putting my foot through the floor a few times on the free way.
If you are towing turn O/D off and you will be fine, also, stock, the tranny is fine. When you start modding and adding power is when the transmission starts to fail.
The absolute WORST thing for our transmissions is sticking your foot to the ground going faster than about 30 miles per hour but with stock power you have no need to worry. I converted my truck back to stock after the burned tranny so I got rid of my superchips and my intake (still have exhaust) and I have done freeway slams tons of times and the tranny has not skipped a beat since so I think you will be fine until you start modding. On dodgetruckworld.com there are TONS of guys who have lost trannys but they are all mainly heavily modded. Don't worry about it too much, you will probably be fine if you are not trying to make your truck a race truck.
on
Welcome to the forum
Your truck has 545RFE transmission, Your transmission holds ups much better than the early transmissions. You have two transmission filters and no bands to adjust. The only things you needto watch for one the o-ring for the filter and ck the bolts/ screws on theside plate of the valve body. They do come loose and break the heads of the screws.
Isn't that the reason they came out with that 7yr, 70000 mile powertrain warrenty, to make up for the bad press on the trannies? And they got rid of that in 06. I know I never have had a problem, and I am probably rougher on it then I should be. But then again, I have the warrenty so I don't worry about it too much.
ORIGINAL: motorider228
Trending Topics
ORIGINAL: John M
So basically you're saying not to pass anyone? WOT is absolutely a valid operating position for the throttle and should not cause damage to any vehicle. The power from an intake and exhaust shouldn't make the difference between a long tranny life and a 6k rebuild interval. Spray it or supercharge it and I can understand transmission issues. Simply driving in a spirited fashion with a few bolt-ons shouldn't spell the end for a transmission.
I tow a camper trailer (about 5000 pounds as towed) quite a bit and have never had a transmission problem. I cannot say much for the differentials however, having the problems that I have experienced. My truck is in the shop atpresent, for the sixth time for differential problems. I don't have any doubts that some of this is due to crummy repairs, but having heard of other people with the same difficulty, I am not impressed with the Dodge rear ends.
So far, it has been repaired under the drive-train warranty, the last time the 3X36 warranty had just expired and it cost me the $100.00 deductable. This time I don't intend upon paying that, hence the reason that I have a post on the forum asking for people's experience with continous problems.
At least one of the problems when the differential croaked was caused by a dealer that put incorrect lube oil in it and also did notadd the anti-slip additive. Other times it may have been caused by improper adjustment when put back up by the repairing dealer but the bottom line is, in my opinion, the differentials in these trucks are just too finicky and not robust enough for those that tow often.
I love the truck otherwise, but I am really frustrated with the rear end problems. If you tow often, be sure and have the rear end lube changed at the recommended 15,000 mile interval and whatever you do, even if you have to talk to the mechanic that doesthe work, make sure the proper lube oil (75W140, Synthetic with 5 ounces of anti-slip additive) is used when it is done. Better still, do it yourself if possible.
The above applies onlyif your truck has the anti-spin differential. Did I mention that my truck only has a little over 37,000 miles on it?
