this is embarrasing but................
Nothing a little power braking won't fix. But I do not encourage that, hard on the truck.
Bigger gears and bolt ons will do it. But why spend money so you can squeel your tires.
1. It will wear down your tires, costing more money.
2. It is illegal, so if you do it and a cop sees you do it thenit will cost you even more money.
3. You are on the gas harder, hense using more gas, and yes, costing you more money.
Seems it would cost you a lot of money just to make a little bit o sound
Other are right... the 4.7 just in'st strong enough... don't get me wrong... good truck... my 05 had a 4.7....IT was hard to light em up... does'nt mean anything wrong... just weak...
ORIGINAL: Ben D.
^^^ this coming from the guy with a viper and srt10. lol jk. I doubt i'd go crazy in those things either they are expensive toys.
Next year I will have some videos of my truck at the track, when I am done with it
Hey, my 3.7 can burn tires. Yes I have manual tranny, which helps a lot. I revved up to 2000-2500 and let go of the clutch. E-A-S-Y, and I have 3.21 gears, no trac loc.
So a 4.7 can do it too.
All you have to do is ruin your transmission, how? E-A-S-Y, put it in neutral, rev up and drop it in D. Easiest way to burn, easiest way to get a new transmission, easiest way to see 2 to 3 large ones leave your pocket.
