Fuel Octane?
Old Jul 10, 2007 | 05:01 PM
  #21
HankL's Avatar
HankL
Default RE: Fuel Octane?
http://sciam.com/article.cfm?chanID=...5F3705197C1D4F
Old Jul 10, 2007 | 05:03 PM
  #22
casper3380's Avatar
casper3380
the prefered octane rating is 89 though 87 is acceptable per the book. the octane rating itself signifies two things, the amount of no knock chemical(by ratio-the chemical name i can't remember at the moment) and the related flash point. 87 octane has a lower flashpoint than 89 and 89 vs 92 and so on. hope that helps
casper
Old Jul 10, 2007 | 05:28 PM
  #23
Brawler's Avatar
Brawler
what about octane boosters? Are they bad for my 5.9L 360? I run 91 because it's the highest i can get here in AZ so if i added a bottle of octane booster is it futile or a good idea? No SC yet but one to come soon.
Old Jul 10, 2007 | 08:58 PM
  #24
bdhuntr's Avatar
bdhuntr
ORIGINAL: Zack1978
ORIGINAL: bdhuntr
ORIGINAL: Zack1978
ORIGINAL: bdhuntr
You should fuel up with the octane rating the manufacturer suggests, unless (as previously mentioned by many) you have installed performance mods that mandate a higher octane fuel.
Octane ratings are a measure of the fuel's anti-knock quality and not its "power", although using the correct grade of fuel can increase an engine's power if it burns that fuel completely rather than pre-detonating it or wasting it unburned out the tailpipe.
Well what does Dodge recc for an 07 2500 Hemi?
Zack
No offense, but it's just as easy for you to search forthat requirement as it is for me.
Regardless, that engine requires 89 octane gasoline.
Well considering the fact that I don't own own one as of yet, I can't simply "look it up"
Zack
I don't own one, either. My Ram has a 4.7L under the hood. But I looked it upby searching this forum.
Old Jul 10, 2007 | 10:11 PM
  #25
Hellbilly1's Avatar
Hellbilly1
man i ran some 110 the other day race fuel that **** was badass and expensive it was sweet truck ran like a raped ape got pretty hot though but was fine didnt overheat
Old Jul 10, 2007 | 11:21 PM
  #26
FFMedic1479's Avatar
FFMedic1479
Does the higher octane screw things up? I am not talking the 93 but the 110+.
Now, I definatly don't think that I am a chemist by any means (I got an "R" in high school chem... worse then an F, kinda like them telling you not to bothertaking it again, EVER), but I took this blue collared type class called Chemistry of Haz Mat for the firehouse. From what I remember, the word octane (8) comes from the chemical composition of C8H18... and the properties of the octane are based on the amount of carbon inside the chemical compound... more carbon more stable,and yields a higher amount of energy (propane has 3 carbons in the chain, resulting in a lower molecular weight being a gasand a lower boiling point, thus giving energy off earlier but not as much). So, the octane rating is the amount of octane compounds attached in the gasoline chemical compound (don't ask me what it is) and relates its properties to that compound. Soooo... if there are more octane compounds attached then there should be more energy and a higher ignition temp. I really need to stop drinking.
I hope there is a chemist on this site that will set me straight because I am probably wrong.
Old Jul 10, 2007 | 11:26 PM
  #27
TReX5.7's Avatar
TReX5.7
[sm=confused06.gif]hmmm what he said lol
Old Jul 10, 2007 | 11:30 PM
  #28
FFMedic1479
Like I said, I need to stop drinking... this **** just comes to me in my altered mental status.
Old Jul 10, 2007 | 11:35 PM
  #29
FFMedic1479
Here, I just googled this page, kinda of blurry but a good explination of the principles of octane: http://chemistry.about.com/cs/howthi...a070401a_2.htm
Please tell me I don't sound like someone else on this site...
Old Jul 10, 2007 | 11:40 PM
  #30
ray97's Avatar
ray97
My 2003 book says to run midgrade 89 octane, and I also want to say to buy a quality gas like chevron or shell. I try to only buy from chevron.
