180 Thermostat
Old Jun 18, 2007 | 11:24 PM
  #21
HuntinHanson's Avatar
HuntinHanson
Default RE: 180 Thermostat
now i thought high heat on engines caused problems? not staying cool. Isnt that like saying my truck's engine has a hard time sitting in the driveway because its not running and getting hot?
Old Jun 19, 2007 | 01:58 AM
  #22
FFMedic1479's Avatar
FFMedic1479
Uh... yeah...
Old Jun 19, 2007 | 02:13 AM
  #23
deanj287's Avatar
deanj287
excessive heat causes problems. to little heat causes problems in the long run also. you gota find a nice medium. like cooking ribs, to much heat and the things burn, not enough and they never cook
Old Jun 19, 2007 | 01:42 PM
  #24
Pappy_FB's Avatar
Pappy_FB
Alright I went over and lerked around at HTC and here is the best post I found...
Posted 24 August 2006
quote:
Posted by SilsHemi
Here's a quote from a Dodge engineer on another site. I actually spoke to him before I did thismod. I wanted to make sure it was the right thing to do. Make sure you install a STAT with a bypass post, like the stock T-STAT has.
quote:
Posted by dodge3471
I also use a 180°F t-stat in my modified 5.7L Hemi Ram and have not had any problems. The 180°F t-stat will lower the under hood temps as well as the air inlet charge temps. The engine will also be a lot less prone to spark knock with the cooler cylinder head temperatures which is very important when the modifications that have been done result in a leaner air-fuel-ratio because of the speed density engine control system which is what the 5.7L Hemi uses. I highly recommend the use of a 180°F t-stat in all modified 5.7L Hemi engines.
As I read this I am hoping I got the right Thermostat (with the bypass post) it was a different part number for the 03 and up and alot pricer.
If not I can return it and getthe Stant 180 thermostat from NAPA, which is posta be the magic bullet. Even though it is 64mm you can trim it down to 63mm (if needed).
As far as Codes go I didn't see to many people say they got codes, their were some that were concerned they would get codes.
Some of the guys that lived in the "Great White North" still used 180s but returned to stock in the winter.
Only after I take out the OEM will I be able to compare them first hand.
Giggity! Giggity! Giggity! I am excited!
Old Jun 20, 2007 | 12:08 AM
  #25
HuntinHanson
good info there pappy, did the one you ordered have the bypass?
Old Jun 20, 2007 | 12:40 AM
  #26
Pappy_FB's Avatar
Pappy_FB
I dunno, but for 30 bucks it ought too.
Hell for 30 bucks it should come with case of beer oran extra set of Arteries forwhen I need aBypass.
Oh forgive me sweet baby jesus for thinking about having a heart attack.
I will keep ya'll informed and take lots of Pics. I promise -before and after pics this time.
Old Jun 20, 2007 | 12:48 AM
  #27
HuntinHanson
indeed definately want the befores!!! no excuses!
Old Jun 20, 2007 | 12:58 AM
  #28
FFMedic1479
mmmmm... beer.
Old Jun 20, 2007 | 02:47 AM
  #29
Pappy_FB's Avatar
Pappy_FB
Found this on a 300 forum
I've looked into the Jet 10183 and it appears to be a good bypass-type stat. The only things that I didn't like was that it had the smaller flow opening and no bleeder hole/dogbone. I think that you would be fine if you used that stat.
Me thinks I saw a mode somewhere on how to drill the bleeder hole to boot.
Old Jun 21, 2007 | 03:23 PM
  #30
eltupac's Avatar
eltupac
I was reading the other thread about performance thermostats and this one.
I am not that familiar with them, all I remember was that my old mechanic told me that my 95 Neon did not need one in. He said that it was only needed in cold climates. So removed mine in the Neon and I guess it was always cycling. Anybody know if this is true and the advantage or disadvantage of it?
The lower the thermostat the constant cooling running through the engine, I would think makes it better, butthe engine in my Neon died due to water spewing out of the spark plug hole. Maybe no thermostat did it in. Just like Tootsie Pops, the world may never know.
