Installed a sub, with my factory sound system
Old Jul 10, 2007 | 03:54 AM
  #21
///Matt's Avatar
///Matt
Default RE: Installed a sub, with my factory sound system
If you look directly against the firewall behind the battery, there is a large (about 4" diameter) rubber grommet with a bulky harness protruding from it. You should run the power cable through there. Be sure to put your inline fuse between the battery and the firewall, still under the hood.
If you look under the dash, you will immediately see that same rubber grommet, directly behind where the trailer brake wires up to (blue connector).
Old Jul 11, 2007 | 10:14 PM
  #22
///Matt's Avatar
///Matt
Good news. =)
I just got my REAL amp. (Back).
It's an amp I used to have, that I had sold, but now bought back.
It's a Rockford Fosgate 801s ...2 channel, 2400w peak, 1000w rms @ 2 ohms per channel.
That should push a little harder than my 360w peak amp. lol.
Old Mar 10, 2009 | 07:01 PM
  #23
sunneh63031's Avatar
sunneh63031
heres a question do i have to kill everything to to the one or both the rear door speakers with the line converter?
Old Mar 12, 2009 | 09:14 PM
  #24
southernbnb's Avatar
southernbnb
where can i pick up a box like yall are talking about? i am very interested in puttin a sub in my truck. i miss the 12s i had in my hatchback before i got the truck!
