ENGINE LIGHT?
Old Jul 25, 2007 | 07:38 PM
LBs Laramie's Avatar
LBs Laramie
Default ENGINE LIGHT?
ok, so my engine light came on last week for a couple days, then went off for a couple days, then on again, off again. i checked the code and it was for an O2 sensor in the left cylinder bank, voltage too high. now, this past week the light has been off entirely. so should i just ignore the situation since the lights out now, or could this be potentially very bad for my engine? i can't have the sensor replaced under warranty unless the light is on. thoughts??? thanks!
neil O>
Old Jul 25, 2007 | 09:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: ENGINE LIGHT?
Call the local dealer and tell them the ck engine lite came and went off after 1 or 2 days of driving, and you would like to bring it in. Don't tell them the codes. Let the dealer tell you.
Old Aug 6, 2007 | 04:45 PM
darkman63's Avatar
darkman63
i just came from a dealer today.it was a cat efficiency code dodge just got the soft ware to flash you truck computer,i have a 05 hemi since it took dodge so long to put otu the software i need new 02 censors and a new cat and they are covered.the cat has a 80,000 federal warranty and the 02's are covered under the 7/70,000
