Lifting ram 1500 2wd v8
Old Jul 26, 2007 | 01:39 PM
Ramit186's Avatar
Ramit186
Default Lifting ram 1500 2wd v8
I'm looking to lift my 2007 ram 1500 2wd v8.Most of the websites that I've searched, have said that thesuspension liftfits the 2002 - 2006 2wd ram 1500 models. Wouldthe liftwork for the 07 as well??
Old Jul 26, 2007 | 01:49 PM
bigjrussell's Avatar
bigjrussell
Default RE: Lifting ram 1500 2wd v8
Need a link to what you're looking at. What I've found is that the 2wd suspension is the same on the 2002-2005 rams and thenthe 2006-2007 models are the same but are different from the 2002-2005 models. Confusing enough? So if they're saying it will work for 2006, it should work for 2007.
Old Jul 26, 2007 | 01:57 PM
Ramit186's Avatar
Ramit186
http://www.roughcountry.com/dodge_2wd_02-05_3.html-- -rough country
http://performancelifts.com/cgi-bin/cart/CST20024.html --CST
http://www.stillen.com/product.asp?i...TKT16&c=SU --Stillen
Some sites say 02 - 05 such as rough country and others for cst and Stillen say other wise.
This my first truck ever owned and I know nothing about lifting.
Old Jul 26, 2007 | 02:11 PM
bigjrussell
I would stick strictly to what they advertise for year. If the website makes it unclear, then ask them about it. You can never be too cautious, especially when buying online.
What I plan to get is this:
http://performancelifts.com/cgi-bin/cart/CSSD1106.html-- CST 4" spindles w/ brake line extension kit
At about $800, you want to make sure what you're getting will work.
Old Jul 26, 2007 | 05:21 PM
sharpshooter's Avatar
sharpshooter
There is a difference between the 06 and 07 where the shock mounts.....So 06 and 07 are the same but they are different, I think the control arms are the same but not 100 %
Old Jul 26, 2007 | 09:02 PM
HammerZ71's Avatar
HammerZ71
02-05 use Torsion Bars up front, 06 & 07 are Coil Overs. Your C/O's are are easier to design a lift for and since more trucks are designed with that setup, you'll find more companies offer level kits, lifts, etc. for that type of setup. Therefore, you will have more choices and best of all they will be cheaper than those made for torsion bars. Rancho has just released a fantastic suspension lift system for '06 & '07 Dodges with Coil Overs called a "Quick Lift", 9 position strut, shock, & spacer all in one for like $199!!!
Plus I've seen coil spacers to level your front for like $50 a pair.
I didn't have anything near this inexpensive when I did my T-Bar setup '04 4x4.
I know 2 people that have these already, very inexpensive, fits big tires and great ride quality compared to body lifts.
Here's a link to a review of the Rancho "Quick Lift":
http://orc.off-road.com/offroad/arti....jsp?id=389716
Old Jul 26, 2007 | 10:49 PM
sharpshooter
I tried the spacer kit from RC and lemme tell you NOT A PLEASANT EXPERIENCE....Go for the spindles man youll thank me for it.....Oh and the link you posted is for a 4wd
Old Jul 27, 2007 | 12:40 AM
bigjrussell
ORIGINAL: HammerZ71
2006 and 2007 2WD do not use coil-over struts. They are a standard coil spring and seperate shock. As sharpshootersaid, a spindle kit is the best option.
