CB RADIOS!
Old 08-30-2007, 04:05 PM
HAWKDRIVER's Avatar
HAWKDRIVER
HAWKDRIVER is offline
Default RE: CB RADIOS!
How about in the centr console/armrest/middle front seat. I looked at my '02 and that looked like a cool out of the way place. Plenty of room, plastic surface to mount it to and keeps a hidden look.
  #22
Old 09-01-2007, 08:28 PM
mopar74's Avatar
mopar74
mopar74 is offline
http://www.walcottcb.com/index.php
Anyone still interested int the Cobra 75 WXST it is now on sale at Walcott.
  #23
Old 09-01-2007, 09:07 PM
moparmutt's Avatar
moparmutt
moparmutt is offline
I'm just curious. Where are you guys putting the antennas?
  #24
Old 09-06-2007, 02:40 AM
mopar74's Avatar
mopar74
mopar74 is offline
I picked up the Cobra 75 WXST and installed and tuned it at the CB shop in about twenty- minutes. I have read the post on the Cummings thread an found the vents to the outside behind the rear seat. I was able to fish a wire behind and out to the space behind the cab and the truck bed.
The antenna is mounted to the top of the Trac Rac where I made a steel mounting plate for grounding. Signal is perfect!
I can't get my large hands between the two. I think it would be easier if I could remove the back seat back. I have the BENCH flip up rear seat and have not figured out how to remove the back and get straight access to the vents. ANY HELP? Or other locations for getting the antenna coax into the cab and to under the drivers seat without drilling holes?
  #25
Old 10-06-2007, 01:12 PM
moparmutt's Avatar
moparmutt
Finally... got my cb in and working.
I didn't want to drill a hole for the antenna but I didn't want the wire showing either. So Dad and I drilled a hole and mounted it to the bed. I fabed a bracket to mount under the center seat(no drilling). I made the bracket so the cb will slide in and out and store in the lower center console. So, if I had to haul a third person up front I could. Hers some pics.
Also I can still use everything with it in place like the cup holders and console.
  #26
Old 10-18-2007, 12:46 PM
RedHemi05's Avatar
RedHemi05
RedHemi05 is offline
I don't see the pics bro, maybe I'll have to wait till I get home. I am on a government computer since I work for the Federal Government.
I myself have been thinking of fabing up some sort of bracket and mounting it on the front above the Tran hump. What do you all think?
  #27
Old 10-19-2007, 06:59 AM
moparmutt's Avatar
moparmutt
Redhemi, I will put some pics in my gallery tonight so you can see them.
  #28
Old 10-19-2007, 06:08 PM
moparmutt's Avatar
moparmutt
Ok Redhemi, try looking in my gallery. I added a couple more pics so you can see what I did. I also put wire loom on the wires, just didn't have it done when I took the pics.
  #29
Old 10-20-2007, 03:44 AM
csutton2500's Avatar
csutton2500
csutton2500 is offline
i mounted mine on the side of the transfer case shifter on the drivers side and got my wires hooked to a cigerette adaperter then ran the antenna cord under the front seats and drilled a hole under the back seat(idiot) but it works then to the bed just another idea i looked and looked for ideas too
  #30
Old 10-21-2007, 01:01 AM
RedHemi05's Avatar
RedHemi05
ORIGINAL: moparmutt
Hey Bro I had thought of doing that too. But I didn't have a bracket tat would stick out far enough from my handle to flip that center seat up. Think ya could hook me up. Let me know how much if you deside to.
Nice truck too by the way.
Quick Reply: CB RADIOS!
