K&N CAI Installed
Old Aug 11, 2007 | 11:44 AM
  #21
cableguy1224's Avatar
cableguy1224
Default RE: K&N CAI Installed
Sure would be nice to hearwhat all that hard work did for the truck. LOL
I think someone forgot all the juicy details. SOUNDS, POWER GAIN
Very good step by step install man!!!
Old Aug 11, 2007 | 12:58 PM
  #22
steve05ram360's Avatar
steve05ram360
I dont think that is the stuff to use... I had some hood insulation that was given to me, one side had a heavy foil type of material while the other had the insulation. put the foil side out and bolted it down in a couple of places.worked perfect.
Old Aug 11, 2007 | 02:37 PM
  #23
Pappy_FB's Avatar
Pappy_FB
The way I was thinkin was a two piece set up.
The first piece would mounted to the air box and have thesame size hole (as the air box)
The second piece would be mounted to the tube and somewhat flush against the first piece. it would allow for engine movement and restrict hot air entering the box.
Just my thoughts...
Old Aug 11, 2007 | 03:03 PM
  #24
Pappy_FB's Avatar
Pappy_FB
My Photopaint skills aren't that great but, this is what I am trying to convey.
This is an exploded view of course, filter not shown.
[IMG]local://upfiles/59926/2DD847A6D28A4240AF9D59722B3FAD08.jpg[/IMG]
Old Aug 11, 2007 | 09:33 PM
  #25
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
I might think of using some of the floatation from old rotting lifejackets which looks very similar to the white foam you have pictured. Ideally I will look for some gasket material like is used around the CAI already. Something that can seal but still be flexible.
As far as performance gains, I will post tomorrow. I ran a bit today and I actually could "hear" the difference when I jumped on the gas (open mouth and insert foot). Like I said I will try tomorrow and see what I get. Since I have no dyno I will use my old handy dandy notes I keep on 2 tests I have ran since I bought my truck, 0 -60 and 40 - 70. Every change I make to my truck I record the difference. I'll let you know tomorrow afternoon.
Old Aug 11, 2007 | 09:35 PM
  #26
Pirata's Avatar
Pirata
Your photoshop skills convey the point. I am going to try something like that when I add a gasket. My is to allow movement but still seal off the CAI.
Old Aug 11, 2007 | 11:53 PM
  #27
HighDuke1911's Avatar
HighDuke1911
ORIGINAL: Pirata
ORIGINAL: HighDuke1911
Nice!! I like the step-by-step photos! Does the truck sound better now and run much stronger?
Either I need to get my hearing checked, probably, or those that "hear" a difference need to have their head examined.
OK, smartass, do you HEAR the intake sucking in a lot of air? Make it sound "kool?" You know, kinda like a vacuum but much more silent...
Old Aug 12, 2007 | 08:46 AM
  #28
Pirata's Avatar
Pirata
When I jump on the gas I definately hear a difference. I'll post more later after I have had a chance to test it this morning some more.
Old Aug 12, 2007 | 03:28 PM
  #29
HighDuke1911
Kool. And how much did this thing cost ya?
Old Aug 12, 2007 | 04:19 PM
  #30
Pirata's Avatar
Pirata
220 off of fleabay. I am very impressed with the results too. My truck hauls *** when I jump on the gas.
