K&N CAI Installed
Old 08-10-2007, 06:04 PM
Pirata's Avatar
Pirata
Pirata is offline
Location: 2nd star to the right, then straight on until morning
Default K&N CAI Installed
Sorry Pappy 5 minutes after I sent you the PM stating Monday my daughter came up with a huge box that could only be one thing. I'll skip the narration and answer questions when asked.
[IMG]local://upfiles/59786/5449BCEECC4E4E20ACB2E25CC931AABE.jpg[/IMG]
[IMG]local://upfiles/59786/5A7A5F9BC39F43FCAB3AA6D24E024598.jpg[/IMG]
[IMG]local://upfiles/59786/F8C3D9806D184B6E9888E5A649F0CBDD.jpg[/IMG]
[IMG]local://upfiles/59786/B539436D5784408FAFDF23A170D2E30E.jpg[/IMG]
[IMG]local://upfiles/59786/17B482C6BDDC47E6B67EE335947EFF05.jpg[/IMG]
Old 08-10-2007, 06:05 PM
Pirata's Avatar
Pirata
Pirata is offline
Default RE: K&N CAI Installed
Next batch
[IMG]local://upfiles/59786/2C1E8BDCBA4D4D05A17FA1FCB1B07DDB.jpg[/IMG]
[IMG]local://upfiles/59786/501FA8ECA8B54006AEA7C3FC8420DAAB.jpg[/IMG]
[IMG]local://upfiles/59786/99E01BE16A534AA7ADCB25BBD2B1A9E0.jpg[/IMG]
[IMG]local://upfiles/59786/FEA9FC8EA0774C6C961E49F9E3F0E1A6.jpg[/IMG]
[IMG]local://upfiles/59786/ACF3E03577614B829C36AC1683F8DC34.jpg[/IMG]
Old 08-10-2007, 06:06 PM
Pirata's Avatar
Pirata
Pirata is offline
Next
[IMG]local://upfiles/59786/15E2B7968A4440008E7E4C70D7350F59.jpg[/IMG]
[IMG]local://upfiles/59786/DEF1D0E0CD0445A5AE2A1CC441FF8405.jpg[/IMG]
[IMG]local://upfiles/59786/734A87124BA0494296E50DAF8013C3B0.jpg[/IMG]
[IMG]local://upfiles/59786/261FF42B8D5049029877567E86C3CE9E.jpg[/IMG]
[IMG]local://upfiles/59786/939C559CBD84437AACA4D32C5164E106.jpg[/IMG]
Old 08-10-2007, 06:07 PM
Pirata's Avatar
Pirata
Pirata is offline
Last ones
[IMG]local://upfiles/59786/50B7EBB4C53F4CFBB4481FA0D2594FC0.jpg[/IMG]
[IMG]local://upfiles/59786/AE7D03F287D24ABC88E2C7C09C29B587.jpg[/IMG]
[IMG]local://upfiles/59786/9AA11371FF97432E98B21423856B5226.jpg[/IMG]
[IMG]local://upfiles/59786/C75DE04228234C5F938E34AA92003445.jpg[/IMG]
[IMG]local://upfiles/59786/077F2798142B43D0981BCB3E6E3B0474.jpg[/IMG]
Old 08-10-2007, 06:12 PM
Pirata's Avatar
Pirata
Pirata is offline
The kit was really easy to install. The instructions included step by step pics along the way. I will admit being a little intimidated by the instruction because they included like 30 some odd steps however each step was only one thing to do rather than 4 different things to do within each step like I am used to. As far as I can see the only thing I am not thrilled about is where the hose goes through the cold air box. There is a space of about 1" at the top for hot engine air to enter. I am planning on adding a gasket, similar to the gasket that seals off around the hood, in the near future.
Old 08-10-2007, 06:16 PM
Dire Wolf's Avatar
Dire Wolf
Dire Wolf is offline
WOW
Old 08-10-2007, 06:36 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Sir Hardin Thicke is offline
ORIGINAL: Pirata
Next batch
For a moment I thought you were mounting this behind your grill. Now I see you just set it there to snap a photo.
Old 08-10-2007, 06:55 PM
Pirata's Avatar
Pirata
Pirata is offline
Yes, my radiator was full of parts and tools so this one didn't fit. I forgot to add one more thing, it said in the instructions that I needed a 7/8" drill bit. WHERE? I searched the instructions thoroughly for where I needed to drill anything and didn't find anything. For those of you who don't know a 7/8" drill bit is not a common size you'd buy in a set. It's a bit you'd buy one at a time. My largest drill bit was a 1/2" so I figured since I didn't see the hole that needed to be drilled I would jump off that bridge when I got to it.
Old 08-10-2007, 06:57 PM
moparmutt's Avatar
moparmutt
moparmutt is offline
Looks great. That's the same one I would like to buy.
Can you put the hemi cover back on or does it not fit now?
It also looks like it is sealed off well. As far as water and such.
Old 08-10-2007, 07:12 PM
Pirata's Avatar
Pirata
Pirata is offline
The hemi cover is actually part of the air intake system. It has a 90 degree turn built into it for the air to enter the engine. The 4th pic I posted shows the intake hole in the Hemi cover. The 6th pic shows where the Hemi cover intake meets the engine. I suppose if you wanted you could get creative with a dremel and cut out all of the air intake and surrounding areas so that this could fit over the CIA. One down side is that themid support of the CAI isbolted in where the orioginal cover was secured.
Quick Reply: K&N CAI Installed
