tune up
Old Aug 11, 2007 | 11:35 PM
MR.5.9's Avatar
MR.5.9
Default tune up
well, im right around the cornor of 80k on my truck and im pretty sure it could use a tune up. i grew up on european cars and toyota pickups. this is my first ever american car/truck. heres a list of stuff i put together to change on it. i bought the truck with 70k on it so im not sure what has been done to it so i figured go all out.
plugs, wires, oil, oil filter, air filter, distributer cap, fuel filter, tranny service, trasfergearbox oil, rear end oil.
if i missed anything else let me know. also ive been using amsoil 0w-40 full syn on my other cars, what does a good job on the 5.9?
Old Aug 12, 2007 | 12:54 AM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: tune up
fuel filter is non serviceable on the trucks (at least 04 is, so i'm assuming 02 is the same)...as for engine oil...i always use Mobil 1with a Wix filter...make sure you use the correct trans fluid (ATF +4), use syn. in the diffs...so on so forth and you should be set...good luck
Old Aug 12, 2007 | 02:07 AM
ozzy55's Avatar
ozzy55
Default RE: tune up
not sure what the owner's manuel says, but you will probably need to flush the radiator also
Old Aug 12, 2007 | 04:06 AM
MR.5.9's Avatar
MR.5.9
Default RE: tune up
how much do you think the dealer would chard for a full service like this? id love do do it myself but im one busy sum-bitch
Old Aug 12, 2007 | 05:09 AM
ozzy55's Avatar
ozzy55
Default RE: tune up
last one I had done was on my jeep wrangler and it was around $300 for everything
Old Aug 12, 2007 | 07:28 AM
LoFlyer's Avatar
LoFlyer
Default RE: tune up
I'd add radiator cap and new serpentine belt to your list.
Old Aug 12, 2007 | 08:54 AM
Wishbone's Avatar
Wishbone
Default RE: tune up
Owners manuel says to change the spark plugs every 30K so I'm guessing these are not platinum plugs, just regular?
Old Aug 12, 2007 | 09:55 AM
aaronstottle's Avatar
aaronstottle
Default RE: tune up
They are regular copper core plugs from what I understand. I have been told not to use anything else with my truck, other than original equipment style plugs.
Old Aug 12, 2007 | 11:12 AM
Wishbone's Avatar
Wishbone
Default RE: tune up
Probably a good idea, even better idea on the Hemi. I suppose titanium or iridium will make the truck run way too hot.
Old Aug 17, 2007 | 03:39 AM
ttuguy1983's Avatar
ttuguy1983
Default RE: tune up
You could switch to a better oil filter....like a k&n or some other high performance filter.
