some mantenance
Old Aug 22, 2007 | 08:41 PM
moparmutt's Avatar
moparmutt
Default some mantenance
I bought my truck with 16,000 miles on it. I now have 16,787. I want to check the lsd. It feels like a slight shudder in slow turns.My Dad thinks a service will cure it. Plus I don't think the dealer did one. So I'm going to service the diffs this weekend.
Can I use synthetic in the front axle? Today I bought the lsd additive for the rear. I asked the parts counter at dodge, but she looked at me like I was stupid. I guess I will go to auto parts store and get the oil. I read it calls for synthetic 75-140 for the rear, but regular 75-90 for the front. Do you guys use gaskets or just sealer on the covers?
Also the only thing I can find (in the owners manual) on the automatic trans and transfer case says to service at 60,000. Is that right? I thought it was 30,000.
Thanks, Nick
Old Aug 22, 2007 | 08:46 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: some mantenance
U can use just sealer, dont forget the additive if you have the LSD in the rear!
Old Aug 22, 2007 | 08:51 PM
nastyram's Avatar
nastyram
i put syntetic in both front and rear on mine never had a problem
Old Aug 22, 2007 | 08:59 PM
chadrules's Avatar
chadrules
ORIGINAL: HansonHVAC
At 412 miles, not worried yet, but what's this about an additive if you have limitied slip?
Old Aug 22, 2007 | 09:11 PM
nastyram's Avatar
nastyram
when you service your rear if you have lsd you have to put an additive in to keep the clutches lude up
Old Aug 22, 2007 | 09:47 PM
hemiyellow's Avatar
hemiyellow
DC Insider
it's just a friction modifier for the clutches....i'd check and see what axle you have in the front, cause one says to use it and the other doesnt.....prolly be ok using it tho
Old Aug 22, 2007 | 10:09 PM
JimmyDiablo's Avatar
JimmyDiablo
I was under the impression that if you use Royal Purple that you do not need to add the friction modifier.
Old Aug 22, 2007 | 10:18 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i wouldnt trust it....specially if still under warranty then deffinitly add the LSD modifier......if out of warranty well....spose at the freedom to do whatever ya want i guess lol...but i would add it either way
Old Aug 23, 2007 | 02:23 PM
88xj's Avatar
88xj
Member
i just used royal purple in mine i have no problems at all .
Old Aug 23, 2007 | 05:40 PM
moparmutt's Avatar
moparmutt
I know I have a LSD. Got the additive the other day.
So, synthetic in the front axle will be ok?
How about the trans and transfer case, every 60,000?
