Door Open Chime?
Old Aug 24, 2007 | 07:55 PM
Hessmonster's Avatar
Hessmonster
Default Door Open Chime?
Is it possible to turn off the door open chime, when I have the keys in the ignition (acc position) listening to the radio with he doors open?
Old Aug 25, 2007 | 02:36 PM
Brother Rob's Avatar
Brother Rob
Retired Moderator
Default RE: Door Open Chime?
Yessir. Read your manual. There is a procedure for disabling that chime, the seat belt chime, etc...
Old Aug 25, 2007 | 02:39 PM
Brother Rob
Retired Moderator
Just an after thought. Do you realize that that chime is there, to help you NOT to lock your keys in your truck?
Old Aug 25, 2007 | 09:00 PM
Hessmonster
yea but I want to listen to music with the doors open more than I lock the keys in it. Thanks
Old Aug 25, 2007 | 09:58 PM
nastyram's Avatar
nastyram
will is work on an 02 qc?
Old Aug 25, 2007 | 10:04 PM
hemiyellow's Avatar
hemiyellow
DC Insider
turn the key to "Run" not "ACC" and it wont chime
Old Aug 25, 2007 | 10:11 PM
nastyram's Avatar
nastyram
yeah but i don't wont everything powered up,just the radio
Old Aug 26, 2007 | 07:03 PM
damquick1's Avatar
damquick1
you cant lock the door on my 06 with a key in the ignition, if you can't get it to work with the manuals instructions take it to the dealer and have them hook it up to the STARSCAN, they can shut it off in there, will take like 10 minutes.
Old Jan 18, 2008 | 10:55 PM
3twos's Avatar
3twos
HELP! We have not found anything in our manual regarding turning off the door chime -- only the seat belt. Thanks, ~Sheila
Old Jan 12, 2019 | 12:48 PM
Jordan Armstrong's Avatar
Jordan Armstrong
Default Disabling door ajar chime
If your trying to listen to music with the door open without turning the key all the way simply switch the latch in your door. It should lock in the closed position while the doors open if ya move it down. Problem solved without pulling wires 😯😯
