Best Synthetic Oil
Old Sep 24, 2007 | 12:43 AM
lewpuckett's Avatar
lewpuckett
Default Best Synthetic Oil
I have 1500 miles on my Ram and I am going to switch to synthetic. With Royal Purple,Amsoil,Mobile one and others which do you feel is best?
The only things I have read says Amsoil is best, but Royal Purple advertises horsepower and horsepower gains. Mobile one seems to be the easiest to find. Let me know what the forum thinks.
Old Sep 24, 2007 | 12:44 AM
tdmopar59's Avatar
tdmopar59
Default RE: Best Synthetic Oil
do a search this has been posted many times including a poll i personally use mobil 1 and a wix filter
Old Sep 24, 2007 | 12:57 AM
cyclone429's Avatar
cyclone429
Red heads, Blond's, smart, or easy, plain or sassy, oil is like women, manny chioces with manny options, as long as you keep booth healthy and maintained, the better you will be.
I use mobil 1 with the chrysler oil filter ( don't know if its a Fram, puralter with the chrysler name on it )
Old Sep 24, 2007 | 01:05 AM
aceman402006's Avatar
aceman402006
i have always heard royal purple is the best expensive but the best i will be switching it to that when i get the money
Old Sep 24, 2007 | 01:08 AM
tdmopar59's Avatar
tdmopar59
it is said that royal purple thins out quickly and doesnt protect as well as other oils
Old Sep 24, 2007 | 05:05 AM
NYPANAMA42's Avatar
NYPANAMA42
Well, i've been using Mobil 1 since i purchased my truck, and it appears to be working fine..
Old Sep 24, 2007 | 06:24 AM
HammerZ71's Avatar
HammerZ71
ORIGINAL: tdmopar59
That's interesting, is that hear-say, or is there test data? I'm currenty using Valvolene Full Synthetic (went in to get Mobil 1 but couldn't resist the buy one, get one free sale) but have recently read two separate tests where Royal Purple and Amsoil both held their properties much longer than all other synthetics tested. Amsoil actually tested best, but just ahead of RP and they were both WAY better than the rest.
Unless I happened to step into another buy one/get one type deal, I was thinking about RP next change. I was thinking about Amsoil, but it's too much of a PIA when you can't just walk into the store and buy it.
Old Sep 24, 2007 | 07:23 AM
Vandersnoot's Avatar
Vandersnoot
ORIGINAL: aceman402006
Royal Purple is only about $1.30 more per quart than Mobil 1......Just FYI
Old Sep 24, 2007 | 08:22 AM
Pappy_FB's Avatar
Pappy_FB
If you have the money go with Amzoil
But like cyclone said if you keep it maintained you'll be just fine with a less expensive brand.
Old Sep 24, 2007 | 09:25 AM
HankL's Avatar
HankL
Mobil 1 has the most research behind it
and has had the most money spent testing it.
The Dodge Viper, Corvette and the Porsche 911
have been shipped from the factories with Mobil 1 original fill.
Exxon/Mobil recently did a 'round the world' test of Mobil 1 in engines:
http://mobil1.com/USA-English/MotorO...orld_Home.aspx
volunteers have tested Mobil 1 and other syn oils:
http://neptune.spacebears.com/cars/stories/mobil1.html
I have used Mobil 1 starting in 1976
but have had problems with it attacking gaskets
and allowing leaks in the early days.
I have used Mobil 1 in a 1995 Magnum 5.9V8 since 18,000 miles
and now have over 180,000 miles with the cylinders all still showing
compression over 140 psi on the 4th stroke in a hot test with the throttle propped open.
