emission light
Old Sep 28, 2007 | 09:23 PM
socomkid97's Avatar
socomkid97
Default emission light
hey guys, this light on my dashboard is coming up. i looked in the manual and it said that it was something dealing with the emissions, i have no clue what that means. i have my cats on. please help
Old Sep 28, 2007 | 09:43 PM
nastyram's Avatar
nastyram
Default RE: emission light
what model,what motor,stock exhaust,aftermarket exhaust
Old Sep 28, 2007 | 09:49 PM
socomkid97's Avatar
socomkid97
its a dodge 1500 2003. i have a magnaflow muffler with dual exhaust
Old Sep 28, 2007 | 09:57 PM
nastyram's Avatar
nastyram
what motor
Old Sep 28, 2007 | 10:03 PM
socomkid97's Avatar
socomkid97
oh yea, sorry. the 4.7
Old Sep 28, 2007 | 10:07 PM
nastyram's Avatar
nastyram
check the gas cap,whent throught this a few months ago and that was the problem
Old Sep 28, 2007 | 10:08 PM
socomkid97's Avatar
socomkid97
ok i'll try tommarrow. but that could be it because the light came on one day right after i put gas in....thanks
Old Sep 28, 2007 | 10:18 PM
nastyram's Avatar
nastyram
yeah its possible,some trucks if you leave them runnin when fuelin them the light comes on,also over fillin them to,but the light should go out when corrected
Old Sep 29, 2007 | 11:23 AM
socomkid97's Avatar
socomkid97
ok i tried tightening it and its still on, anyone else have any idea?
Old Sep 30, 2007 | 09:28 AM
gchildre's Avatar
gchildre
You didn't mention a dealer so I assume you are out of warranty. If you just out of your overall warranty don't forget that manufacturers often have a longer warranty on emissions systems, I think the government forces them to warranty emissions systems longer than the base warranty. If that is not an option then check your local autoparts stores to see if they will do a code scan for you for free,I know Advance Auto Parts will do this for you in hopes that you will spend your money with them fixing it. You will have them scan the truck and then note the code or codes (the codes are a letter and four numbers like P####). Write the codes down and then go to http://www.obd-codes.com and search for the code(s) meaning. This will just be the first step as you may get a somewhat cryptic code answer but it will at least point you in the direction of the source of the problem. Post back or search this site with what codes you get and I'm sure you will narrow it down. You could have vapor recovery, cylinder misfire, O2 sensor or other emissions specific codes. Once you fix the source of thethen the scanner can also clear the codes to see if you have fixed the problem.
Good luck
