Pissed
Old Oct 5, 2007 | 10:06 PM
sroswat0911's Avatar
sroswat0911
Default Pissed
I'm new to the board and a new Dodge owner so i'll make this quick. I bought a brand new 07 Ram Quad-cab 4x4 w/ the 5.7 hemi last Sat. night. Things were going well until last night when I went out and decided to run a errand w/ my wife. Engine cranks up but the check light comes on. It has less than 250 miles on it and the light comes on. What's the deal? Has anyone had this happen to a brand new truck or is it just my luck?
Old Oct 5, 2007 | 10:16 PM
HammerZ71's Avatar
HammerZ71
Default RE: Pissed
Bring it into the dealer, they will scan the code and know what's up. If you are goingto have a part fail, there is a 90% chance it will do so in the first 1000 miles, could be anything from a bad sensor to a sticky valve. Odds are it's no biggie, and when replaced or fixed will never happen again. Hell, it could be that your gas cap is not screwed in all the way.
Old Oct 5, 2007 | 10:24 PM
cyclone429's Avatar
cyclone429
Default RE: Pissed
I can't find the right words that is going to make all the check engine lights, **** poor service from my dodge dealer, sqeaky front suspension that never is acting up when truck is in for service or the F...idget who failed to properly torque the bolts on the front diff of my 2500 Ram ( after I paid good money for new fluid in the diffs and transfer case )
The Ram it self is a dam fine truck, I say this after years of only owning Fords and thier horror stories.
Just when I thought my dealer turned the page for the better, they did not.
If its mecanical, electrical, and has coumputers and assembled by man, issues major or minor are going to occur with any brand.
Don't get up set over a check engine light, this is minor, reset the coumputer ( pull negative + bat cables from the batery wait five min, reconect) if light comes back, go to the dealer.
Hang in thier, I pay good money for my truck as well, and welcome to the board.
Old Oct 5, 2007 | 10:35 PM
sroswat0911
Default RE: Pissed
ok, thanks guys. Just needed to vent a bit. The dealer did give me a rental and got me out of there pretty quick and on my way so they could do their thing.
Old Oct 5, 2007 | 10:45 PM
HammerZ71's Avatar
HammerZ71
Default RE: Pissed
ORIGINAL: sroswat0911
When you pick up your truck, ask the dealer exactly what code was generated, better yet make sure it's on the warranty work slip, they will usually put the code # but if not, ask them to. If they ask you why, tell them you want to keep accurate service records.
Then post the code on here,one of us cantell you EXACTLY what was wrong, and if it should cause any future concern.
Old Oct 5, 2007 | 11:10 PM
steve05ram360's Avatar
steve05ram360
Default RE: Pissed
Agreed with the 90% comment... goes for all electronic parts, if something is going to fail, it'll happen real quick. let us know what it was if you would...
Old Oct 6, 2007 | 12:07 AM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: Pissed
welcome to the forum. I m sure it is something minor. just wait to get it back, you will be alright
Old Oct 6, 2007 | 06:55 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Pissed
Loose gas cap?
Obtained from the DIY post above.
https://dodgeforum.com/m_691136/tm.htm
Old Oct 6, 2007 | 07:02 AM
thankuhal's Avatar
thankuhal
Default RE: Pissed
Yes, I have seen a few trucks and cars come in to our dealership in the past few weeks. I dont know the codes they had, but, the customers were in and out within 30 mins. Had one come in yesterday amd it just came off the truck with 3 miles on it.
[IMG]local://upfiles/71292/4B103CD28510415BA7DDDC81BDE411DF.jpg[/IMG]
Old Oct 6, 2007 | 08:52 AM
Rebel9846's Avatar
Rebel9846
Default RE: Pissed
I don't know about the rest of the country but here on the west coast, autozone will hook up to your OBD2 and scan it for free as long as you get there before dusk. It's the same as taking it to the dealer, just less turn around time involved. Depending on the code you can get it in the shop if you need to. Do NOT ignore/clear the code. For all you know it might be running lean and that's a serious problem. Check it out if for nothing more than peace of mind.
