cranked the torsion bars
Old Oct 11, 2007 | 11:19 AM
  #31
Duso02's Avatar
Duso02
Default RE: cranked the torsion bars
ORIGINAL: OldMoparMan
They also make shock absorber mount extenders, so no replacement is necessary......
Yep, and you usually get them free with the keys!![8D]
Old Oct 14, 2007 | 12:09 AM
  #32
tommygun89's Avatar
tommygun89
so, a 1 inch lift to the front end is easily done by cranking the torsion bars?
I havent found a topic or link that explains "How To" do this w/ pics... any suggestions...
and from what i'm reading, you must have truck allignt after doing this?
Old Oct 14, 2007 | 07:14 AM
  #33
moparmutt's Avatar
moparmutt
Yes you can raise it by tightening to torsion bars. And diffidently get it aligned after doing so.
I haven't done it yet, so someone correct me if I'm wrong. But have the the truck sitting on a level surface, jack the front end off the ground, tighten the torsion bolts some, lower it down and measure it. I would move it around a little to see if it settles. Keep doing this to get it where you want it.
Old Oct 15, 2007 | 11:39 AM
  #34
1SWTHEMI's Avatar
1SWTHEMI
If you crank the torsion bars you shouldn't raise it anymore than 2" or you will need longer shocks, if you dont go any higher than 2" you dont need the new shocks but I would recomend it. Either way you will have to get an alignment.
