Difference in Hemi vs 4.7 aftermarket intakes?
Old Oct 8, 2007 | 10:11 PM
///Matt's Avatar
///Matt
Default Difference in Hemi vs 4.7 aftermarket intakes?
Is there one? They pretty much look like they're interchangeable.
Has anyone tried to fit a Hemi-designed aftermarket intake to their 4.7, or vice-versa?
Old Oct 8, 2007 | 10:17 PM
SWOS Chief's Avatar
SWOS Chief
Default RE: Difference in Hemi vs 4.7 aftermarket intakes?
I don't think that the Hemi/4.7 is what makes the difference. I believe it would be the size of the throttle body intake. Now, I am not a mechanic by any means but seems the intake for a 5.7 litre would be larger than that of an 4.7.
Old Oct 9, 2007 | 01:27 AM
///Matt's Avatar
///Matt
in all probability, yes. The throttle body should be a larger diameter, but I'm not certain. I don't have a Hemi. =(
I just want to know if anyone's tried this.
Old Oct 9, 2007 | 09:50 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
If your asking because you found a deal on an intake for the wrong engine, remember you can always buy a silicon adapter for the throttle body, say a 3.5 inch to a 3" adapter for plumbing to replace the regular adapter that goes to the trottle body with the kit.
Old Oct 9, 2007 | 10:54 AM
Max Power's Avatar
Max Power
There is a difference. Multi-fit intakes block the oil dipstick tube on the 4.7, if the intake also fits the Hemi. If you have a 4.7, buy an appliication specifically for that, not multi-fit.
Old Oct 11, 2007 | 12:42 PM
myhemi's Avatar
myhemi
I don't know that it is recommended, but I bought a cold air intake kit from Volant for the 4.7L in '02. Then I bought an '03 Hemi and put the cold air kit on with no problems, there is an orange rubber ring that is on the throttle body or it may stick to the factory intake. Take the orange ring off and the Volant intake slides right on. I am currently using the intake on an '07 but I had to do some minor modifications.
Old Oct 11, 2007 | 12:47 PM
287cc's Avatar
287cc
Just about all intakes will work on either 3.7,4.7, and 5.7. Minor a few changes in getting some longer breather hose but thats about it.
My airraid is from a 2005 hemi all I had to do was get a longer breather hose.
But I do know that if you get one of those intakes like aem or mopar the heatshield to bolt up to the radiator will be factor due the year of the truck but not the motor.
Old Oct 11, 2007 | 12:50 PM
287cc's Avatar
287cc
And no need to worry on tb size to have the intake fit.
