pissed
Old Oct 10, 2007 | 05:44 PM
kx250frider617's Avatar
kx250frider617
Default pissed
ok well i did the torsion bar crank but i went to go get it all aligned and two guys said that my camber adjustment was maxed out so i have to put to the stock settings again. Those keys won't work either. So i guess im just going to have to save up for the real lift.
Old Oct 10, 2007 | 06:29 PM
moparmutt's Avatar
moparmutt
Default RE: pissed
That's not good. I was hoping to do the same thing soon.
Old Oct 13, 2007 | 07:50 AM
moparmutt's Avatar
moparmutt
Default RE: pissed
So what did you do?
I have been trying to research it some. It seams like most people have no problems if the go only 2" or less. Also I like that the keys come with a shock spacers so you could still use a stock size shock.
Old Oct 13, 2007 | 12:06 PM
kx250frider617
Default RE: pissed
well i did the crank everthing was fine but when i went to get it aligned they said that me camber adjustment was already maxed out. They said i needed off set bolts that connect the upper control arm t the frame. I would have done it but my dad just said to change it back.
Old Oct 13, 2007 | 05:56 PM
aefwolf's Avatar
aefwolf
Default RE: pissed
You shouldn't go any higher than 2.5 inches if cranking from the Tortian bars, I have done this before and I am going to do it on my new Truck in a week. That kit is only meant to level the truck. If you go more than 2.5 inches, you will not only ware out tires, but the ride is going to bea lot more stiff. If you want to go bigger than than 2.5, you just have to bite the bullet and invest the money.
Old Oct 13, 2007 | 09:41 PM
nastyram's Avatar
nastyram
Default RE: pissed
something doesn't sound right,when i took mine in for alinement it was dead on,i did a few chevys also an they had no problems,i would go somewere else and see what they say.
Old Oct 14, 2007 | 12:45 AM
kx250frider617
Default RE: pissed
what ever i guess it you get what you pay for, and a free lift aint gunna work right. I might just save up and buy a 4' lift and air bags in the rear.
Old Oct 14, 2007 | 01:03 AM
tdmopar59's Avatar
tdmopar59
Default RE: pissed
ORIGINAL: kx250frider617
what about that rancho quicklift system would that work... or if you wanna go 4 inch y not do add a leafs....
Old Oct 14, 2007 | 01:39 AM
kx250frider617
Default RE: pissed
do u have a link. i don't think i've seen it. is it for the 03' or the new coil spring trucks.
Old Oct 14, 2007 | 01:46 AM
tdmopar59's Avatar
tdmopar59
Default RE: pissed
hmmm seem to be for -06's
