Build Sheet Questions/ Rear Questions
Old Oct 25, 2007 | 12:12 AM
JD1500's Avatar
JD1500
Default Build Sheet Questions/ Rear Questions
I just got my build sheet from Dodge, wich took not even 20 hours by the way. Very nice service.
In it, is says i have the trailer tow group, heavy front axle. 3.92 gears and 9.50 Corporate LD rear end. Is LD for limited slip? i dont see anywhere else it says i have it. Just trying to avoid jacking it up.
THanks.
Old Oct 25, 2007 | 12:44 AM
tdmopar59's Avatar
tdmopar59
Default RE: Build Sheet Questions/ Rear Questions
are you sure it doesnt say lsd.... otherwise it could just mean light duty...
Old Oct 25, 2007 | 03:29 AM
thebean's Avatar
thebean
So when you stomp on it, do you lay one track or two? That might tell you if you have LSD.
Old Oct 25, 2007 | 01:19 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Try going here: http://www.dodge.com/en/select BUILD MY OWN and select your dodge. It will give you all the options and many have descriptions about what they are. You can even order it from there as well.
Old Oct 25, 2007 | 03:05 PM
hemiyellow's Avatar
hemiyellow
DC Insider
LD means Light Duty
Old Oct 25, 2007 | 05:55 PM
JD1500's Avatar
JD1500
Well, the window sticker says anti spin rear axle, and the build sheet is for a light duty...so looks like i am jacking it up?
Old Oct 25, 2007 | 07:52 PM
HemiLonestar's Avatar
HemiLonestar
ORIGINAL: JD1500
THanks.
9.5? or is it 9.25? The standard duty rear end is the 9.25" (unless something changed I wasn't aware of). Light duty just means 1500 instead of 2500 or bigger.Usually the specialty packages with the 3.92 gear ratio get the LSD. Look inside your glovebox at the option list sticker in there, should say on it.
Old Oct 25, 2007 | 10:37 PM
kethryes's Avatar
kethryes
ORIGINAL: HemiLonestar
ORIGINAL: JD1500
THanks.
i have the 3.92 gears in mine but i cant find anywhere on my truck or window sticker that says i have the lsd. i got a build sheet and it said that i have the tow package but stillit does notsay i have the lsd.
Old Oct 26, 2007 | 12:15 AM
JD1500's Avatar
JD1500
Yeah misprint. 9.25. I have the heavy duty trans cooler and all that, seems as though my package should have it.
I do not have a sticker in my glove box. Anyone else..seems as though i am the only one
Old Oct 26, 2007 | 12:19 AM
kx250frider617's Avatar
kx250frider617
how did u get it
