Low Gas Light - Noob here
Old Oct 25, 2007 | 08:07 AM
juanovm's Avatar
juanovm
Default Low Gas Light - Noob here
Hello everybody. Noob here, had a magnum and recently changed to an 07 RAM
In my magnum, the gas light would come at at around 1/8 of tank.
i have let mine now go below 1/8 and the light does not come on
does it come one once it reaches the red section?
thanks
Old Oct 25, 2007 | 08:18 AM
tdmopar59's Avatar
tdmopar59
Default RE: Low Gas Light - Noob here
yea it gets pretty low before the light comes on... maybe the tip of the red or lil into it... remember these are much bigger tanks than the one in your magnum
Old Oct 25, 2007 | 08:19 AM
CarGuyOhio's Avatar
CarGuyOhio
Suppose to come on with about 2 gallons left. Considering you have a 26 gallon, that is 1/13 of a tank. Is it accurate, no, but close. Your overhead should read about 30 DTE depending on your MPG.
Old Oct 25, 2007 | 08:48 AM
vwomein's Avatar
vwomein
yeah, if you have the overhead computer, my gas light comes on at 24mi DTE. Then, according to the owner's manual,when it reaches zero, you can go approx 18 miles, but DON'T PUSH THAT! its very approx, but it is good to know that if you get to zero, you're not actuallygoing to be pushing soon. I try to keep it at at least 1/4 tank.
Old Oct 25, 2007 | 11:17 AM
United1's Avatar
United1
The Dodge spec for a low fuel indicator is a 12.5% (1/8) fuel level reading for 10 seconds whenthe vehicle is not in motion or 12.5% (1/8) for 60 seconds when moving.
Old Oct 25, 2007 | 11:55 AM
Foiled's Avatar
Foiled
In the Ram I have went to the station a few times right as my light went on and I would fill up minus 3 gallons.
My Avenger says in the manual the light comes on when there is 3 gallons left.
I remember I would drive over a week with the light on in the Avenger but I don't dare do that in the Ram.
Old Oct 25, 2007 | 01:39 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
ORIGINAL: United1
Ummm, 12.5% is 12.5%, whats the difference in moving or not, at least according to your statement you made.
Old Oct 25, 2007 | 02:07 PM
ItsAVROD's Avatar
ItsAVROD
ORIGINAL: Pirata
ORIGINAL: United1
I would think that with the vehicle in motion the fuel would be moving in the tank, and the fuel level would be constantly "changing" around the sensor. So while in motion, if it reads 12.5% for a minute the system would be sure that the fuel was at or below that level. If the vehicle is stopped then the fuel would not be moving around and the reading would be more accurate hence the shorter time required to kick on the indicator.
Old Oct 25, 2007 | 04:10 PM
Pirata's Avatar
Pirata
Light dawns on a marble head. I see the part of the statement I missed, the elapsed times it needed to register the fuel levels so I see the difference that I did not see before. Thanks for clarifying the part I missed.
Old Oct 25, 2007 | 05:26 PM
MikeHTally's Avatar
MikeHTally
Not a good idea to let the fuel ever get that low. Fuel is what cools a VERY expensive fuel pump. Sometimes, it may be unavoidable, but try to never let it become a habit. I learned the hard way.
