changing my plugs...
has anyone done a diy on this yet??? if not does anyone want one??? i plan on doing it soon using some champion copper cores prolly one day this week.... o and a pcv valve... let me know
Not especially difficult. Back plugs are hard to reach. I bought NGK 5306s. Got sixteen for $28.80. Cost $177 to have 'em changed. Too busy at work at that time, plus I didn't want to deal with the aggravation. As far as "how to", just be very careful not to break the plug wires or get them mixed up. Make sure you blow out any trash before you pull the plug, so nothing can fall into the cylinder. Remove the coil pack, change the plug. Remove the plug wire for that cylinder, change the other plug for that cylinder. Torque 'em to 14 ft-lbs. Apparently, you should not use anti-seize, 'cause it can affect the actual torque on the plug. Fresh dielectric grease can't hurt. Various length extensions, one of' 'em a wobble, will be necessary.
You'll be stretched out across the top of the engine for a while, so a blanket might be a good idea. Seems to take about three hours or so. Take it slow, an' be careful.
i have an aftermarket intake so the box is gone... i know how to change plugs ive been doin stuff like this since i was about 8 years old with my dad... i was wondering if anyone wanted me to do a write up on either thing with some pics when i do it... you know like a couple tricks and tips if i can find any... mainly for the back cylinders...
I see what you meant now that I read it again. I have used write ups that other people have wrote for different jobs and it gave me the confidence to do it myself and save some $$$. I say go for it I am sure you will get some thanks in the future from it. I could have used it when changing my plugs for the first time.
yea i wrote one for the cab lights and have been gettin pm's left and right about it... makes you feel all cool when your like yea i did it and yea i know what im talkin about..
spark plug socket, 6" extention, wobble, stubby 3/8" ratchet, and flex head 3/8" ratchet and you'll be all set....when i did mine, i used a magnet and dropped the socket down into the plug hole then stuck the extension down in there...made it easier to do that way....ended up takin bout an hour
Trending Topics
Yeah, Its not to bad with the right tools. Took me like and hour an a half. The back ones are a pain but not impossible by any means. A little back cramp whenI finished but well worth saving $$$
I did mine just a couple of weeks ago. While you have the top of the engine apart, it's not a bad idea to check the throttle body too. four screws and a plug connection and it can be removed for cleaning. Mine was pretty gunked up (first time in 60k miles), the engine runs much smoother at idle now. I used brake cleaner and a small stainless wire brush to clean all the buildup off the throat and throttle plates. Just don't try to move the throttle plates as this will cause some non repairable damage to the TB. You would have to shell out for a new TB. I put a light film of silicone grease to the bottom mating surface of the TB for sealing and re-installed to the manifold. I did notice during the first few minutes after I started the engine that it had to re-orient the idle setting, but after that, it idled smooth as glass.
Just my .02.
Just my .02.
