Performance parts for 3.7L
Hey guys, i have a 3.7 like most of you all here. if you have any performance ideas for others and myself please feel free to post them here. These are some of the things i have found so far. Let me know what you think of my suggestions as well.
______________________________________
AEM Brute Force Cold Air intake
Jet PCM Stage 1 & 2
Eibach Springs - Lowering Kit[*]Integrated Front/Rear Balance[*]Ultimate On-Road Handling[*]Low, Lean Look[*]Complement Large-Diameter Wheels, Tires[*]Flatter Cornering[*]Lower Center of Gravity[*]Increased Resistance to Rollover[*]Enhanced Response and Stability[*]Excellent Ride Quality[*]Million-Mile Warranty
Jet PCM Stage 1 & 2
Truck
Front Lowers
Rear Lowers
Reg. Cab
1.4"
3.4"
Ext. Cab
1.6"
3.6"
Quad Cab
1.8"
3.8"
I dont think the AEM brute force intake works for our engines? Maybe im wrong. I have the Jet stage 1 pcm....I can tell you now it really helped. Not a signicant notice in power, but it set the RPM's, etc. to a much more efficient level. I also run a Flowmaster Super 40 series exhaust, and an AFE air filter. Frankly, I'd love to do more but Im just not sure what else is really out there.
Well, the factory computer had set a certain limiter on the RPM's so that the truck couldnt be revved past about 3000 rpms. With the jet chip installed, it changed that to about 5000. It also helped change the shift points so that the truck isnt lagging in any certain gear
i have stage 2 and i have seen a decent change. but the difference in stage 1 and stage 2 is the timeing. stage 2 is simply more agressive. i have a 6 speed so there is no rev limiter so i assume that that is an auto thing. i know there is a brute force for our truck let me find it and i'll post the link.
Trending Topics
From what I was told, most of the time a stage 1 chip will help MPG's, and a stage 2 will keep them about the same, but on more expensive premium unleaded. The problem is when most people install the stage 1 or stage 2 chip, the know they have a power adder and tend to drive more aggressive, thus lowering the fuel milage! The same thing goes for exhaust & cold air intakes. (Although I know for a fact that if you let the exhaust back-pressure get too low, or too high, it WILL reduce the MPG's.) As for preformance, read the old post's in here. Just about everything that can be done/said has been done or said in the past allready. WELCOME TO THE FORUM!!!
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
