Oil Pressure? Help please. Update: Worried?
Before oil change noticed top of motor had light oil on it, dealer is looking at it next week.
Did oil change, it is NOT over full. checked it at home, my friends, work. Always cold. Is on the higher side of safe though. Where i always fill too.
My oil pressure gage reads in the acceptible range, but just below the high side, beween half and the higher normal mark.
Just started noticing this, about 2 oil changes ago. Is this something i need to worry about normal? Just hit 30k miles by the way.
Okay.
Checked warm before. sorry typo.
But now.
Checked after got home, few mile drive home from work. All temps at normal. Oil looked perfect. right between the F and the E on stick right after i parked it.
Filler lid, cap whatever it is called. Where you pour the oil in at. I checked the hose to it, it is tight, but when i took the cap off, it had abunch of moisture in it (droplets of water) and has this red/brown funny film all over the inside. Wont rub off, it has stained the plastic. That has me concerned. Any ideas? it hits the stealer tomorrow.
Okay.
But now.
oil will expand when heated jd, if you are filling above the full line it could be comming out, though im not that familiar with the hemi, its possible
he has the hemi mastertech.maybe that oil was there from your last service too, check during this maintenance cycle and see if the oil appears again.
I should have been more clear. My oil pressure gauge reads on the high end like yours JD1500. NO oil on the engine however.
Trending Topics
Yeah, i checked it hot today, and it is still at the top of, but inside the safe line..now i am out of good ideas. should i lower it to the middle of the safe zone?
ORIGINAL: JD1500
update above, but also.
Washed wiped the motor down to get the oil off, as of yet, i dont see any more coming out. but have only put a hundred miles on it or so.
