04 Dodge Ram Overheating?????
Old Nov 12, 2007 | 10:06 PM
  #21
casper3380's Avatar
casper3380
Default RE: 04 Dodge Ram Overheating?????
have you pressure checked the system and radiator cap? could be a pressure issue as well.
Old Nov 12, 2007 | 10:08 PM
  #22
04DodgeRam1500's Avatar
04DodgeRam1500
I think I am going to take it to a shop and just let them check it out. There is to many things it can be. I just need to take it and get it look at I guess.
Old Nov 12, 2007 | 10:25 PM
  #23
sddunn2's Avatar
sddunn2
if you think it might be the thermostat why dont you try taking it right out then going for a drive ??
Old Nov 12, 2007 | 10:51 PM
  #24
04DodgeRam1500
It wouldnt ruin anything and what would that prove exactly?
Old Nov 12, 2007 | 11:27 PM
  #25
sddunn2's Avatar
sddunn2
it would prove that it is not your thermostat . If you take it out you should run cold the vehicle should never really heat up as you will have a continuouseflow of cool water
Old Nov 13, 2007 | 12:01 AM
  #26
287cc's Avatar
287cc
Good point sddunn2...04DodgeRam1500, if you still have had the same problem before the t-stat change its bound to be something else. How are the conditons of the radiator hoses?
Old Nov 13, 2007 | 09:40 AM
  #27
mayfly's Avatar
mayfly
I had the same symptoms on a2001, 1500. I replaced my radiator and all problems went away. Afterwards i tore the old radiator apart.The radiator had a lot of scale build up in the inside. It was so plugged i dont know how any fluid was getting through.
